Results 1 to 25 of 25
    Mar 2014
    Omaha, NE
    Default 8.8 Gear Help Needed
    I opened the differential this evening and I need to know what I have. I'm assuming I currently have a 3.27 gear but I'm not for sure.
    The numbers on the main gear are....
    3 327 E6ZA AA 17 36 2A B
    I have no idea what this rear came out of but I know it's not the factory rear. Any help is appreciated.
    Brock
    Nov 2014
    Grand Rapids, Mi
    3.27 it is. Not THAT common, as most were 2.73 or 3.08.
    May 2014
    Royal oak Mi
    1986 gear (e6)
    FEP Power Member 83gtstang's Avatar
    Shreveport LA
    The 327 was for the automatic car I believe.
    FEP Supporter cmgramza's Avatar
    Dec 2010
    Arlington, Va
    My 86 4cyl auto car came with a 3.27 gear...
    Have
    86 Coupe LX Conversion 5.0 5spd
    70 Mustang Conv. My 1st car. Still have it.
    70 Ranchero 302 Auto
    07 Focus daily driver
    Totaled
    70 Ranchero 351C Auto
    85 Coupe 1 of 62 Sand Beige
    Does it have Traction-Lock/posi?
    Mar 2014
    Omaha, NE
    It does appear so
    Brock
    Oct 2010
    Lebanon, IL
    Count the ring gear teeth, count the pinion teeth and divide the ring gear count by the pinion count.
    BBD PERFORMANCE
    HIGH PERFORMANCE PARTS
    CUSTOM ENGINE BUILDS
    CUSTOM CAM DESIGNS
    1983 CRIMSON CAT OWNER
    Jan 2011
    China Grove, North Carolina
    Same red goo that was on my "3.27" axle so it's been opened. Too bad you didn't find 3.73s like I did! Guy I bought it from sold it to me because it didn't have 3.73s in it! He should have marked it and counted revolutions like I did haha.
    Mar 2014
    Omaha, NE
    Quote Originally Posted by Ethyl Cat View Post
    I'm positive it is a 3.27 gear set since the 327 is stamped on the main gear. I can double check that tonight by counting the revolutions and even the teeth as you guys mention. I also assume that it is the Trac-Loc rear as when you rotate one axle, the other follows in the same rotation.
    What would be the benefits and the downfalls of changing to a 3.73 gear as I have strongly contemplated that move. Being a basically stock 84 V-8, I'm assuming that the change in gears will help it accelerate quicker and have more "seat of the pants" power but will gas mileage suffer much and would the highway cruising RPM's be much higher?
    Brock
    Nov 2014
    Grand Rapids, Mi
    If there was a "perfect" gear, the 373 would have that title, IMHO. When I switched from a 308 to a 373, the car was a different animal. The best bang for the buck, seat of the pants upgrade anyone can do. Mileage will drop a few mpg's, but it's a Mustang, not a Prius.
    Mar 2014
    Omaha, NE
    Good point LOL! Rear gears are something I have never fooled with or seen done, so I might have to find someone locally that is familiar with the 8.8 that can do the change for me if I decide to go that way. I would hate to get something out of whack there.
    Brock
    Jan 2011
    You'll like the 3.27s in that car, that is actually what I wanted after swapping them in a different GT.
    ragtopjr
    Guest
    I agree, and what I found was that for my driving the 3:73 was actually better on fuel then any other ratio I had previously/since.... 2:73, 3:08, 3:55, , and 4:10....
    I plan on sticking a 3:73 8.8 into my stock V8 Anny car next year....
    Mar 2014
    Omaha, NE
    As opposed to a 3.73? I guess everything is subjective to the person driving and I'm sure intended purposes for the car make a difference.
    Brock
    Shreveport LA
    What transmission are you running? SROD, early T5, automatic, T5Z etc? I am happiest with my 3.73 and my 2.95 first gear T5Z. I remember with my old SROD and my 3.35 first gear T5, the car was very "jerky" and would spin crazy off the line, first was almost useless. Was fun though.
    Mar 2014
    Omaha, NE
    Quote Originally Posted by 83gtstang View Post
    This will be with the factory T-5, it's one thing that wasn't changed on this car. I'm not sure what gear ratios they are though, how would I find that out?
    Brock
    Jan 2011
    The 84 I had it in was stock except for exhaust and the 3.27 fit it nicely. I haven't driven one with a 3.73 yet, but if yours is in good condition, I'd try it first and see how you like it before paying for a gear swap.
    Shreveport LA
    Quote Originally Posted by 84StangSVT View Post
    I think you have the non world class T5 then. Should be a tag somewhere or run numbers on the cast somewhere. It's a 2.95 first gear I believe from reading, the world class was introduced in 85 and had a 3.35 first gear. My 83 came originally as a SROD four speed with a 3.07 first gear and was super with 3.73 gears.
    http://chris66dad.tripod.com/id38.html
    This link has a tag reader just type in the numbers
    http://www.5speeds.com/t5/
    New User
    Mar 2015
    Mechanicsville Maryland
    Read the tag on the rear
    On my '85, I had 2.73 on the 7.5.
    I upgraded to the 8.8 and it had 3.08. Gears made noise so I decided to have 3.55's in.
    Better seat of your pants power.......at 70mph the drone was gone as the rev's are higher. Since this was my first experience with a gear swap, I was hesitant fearing too much gear.
    Hindsight, I should have gone with 3.73. Seat of your pants is better.....but could have been better if I had gone with 3.73.
    When I ordered my Jeep Wrangler last year....I ordered it with 3.73 instead of the stock 3.08. Heck I should have ordered the jeep with 4.10 but then I would have had to order a Rubicon and give up a posi rear end for lockers. I don't crawl and my jeep is my DD to get me to the hunt camp....Oops, this should have gone on the wrangler forum HEHEHE.
    FEP Super Member embler's Avatar
    Jan 2006
    high point, nc
    Don't fear the gear
    "I'm a mental patient, I'm suppose to act out!"
    I'm one of the contrary ones that likes the 3.27s behind a manual better than I like 3.55s, let alone 3.73s.
    Gear choice is not just about acceleration for me, I also care about how the car drives in stop-and-go, and
    with 3.55s, 1st gear is all but useless in my '85 hatch. I end up doing about 90% of my acceleration in 2nd.
    Maybe it's an age thing, but over the years, I came to the same conclusion with my 1st-gen Mustangs. My
    '68 ended up with a toploader and 3.25s in the rear, and they're perfect for the way I drive. And that last
    bit is the most important part. There are guys that put 4.10s in a 5-speed car and love them, so it really is
    more of a personal choice, based on what's most important to you.
    Automatics are a different story though, especially if it's an AOD. AOD cars can use just about all the gear
    they can get.
    Cheers,
    Jeff Cook
    May 2014
    Royal oak Mi
    Ford used a 331 gear as well I have one its out of a 05 vert auto
    Would make a perfect power adder gear ratio being between the two popular swaps
    I had 327 355 373 and currently 410 and won't go back
    430 is what I would go with if I had a aftermarket trans with the better overdrive
    As far as 1st gear being useless I'm not sure what that means it's shifted in th middle of a intersection and your n second before you cross the intersection what else is first gear used for ??
    Second gear off the clutch just over ideling is good for a very heavy traffic situation it will just do its thing no bucking or drive ability issues
    As far as being a perfect mpg gear well no
    I'm at 2800 rpm with 26.1 tall tire at about 65 (phone GPS mph) never switch speedo to accomodate gear swap
    When I hear first gear is useless statement for a 410 should not consider no higher than 373 and if you want a 410 your not looking for the best mpg
    Most cams and intake swaps Come alive in the 3200 rpm range
    Try to get your power and there is easily done with gear swap
    May 2014
    Royal oak Mi
    Last sentence supposed to be To get in your power band range
    If your curious how 3000 rpm is on the e way put it in a gear that will allow you to be a 3k around 70 prob 3rd gear or so
    A 28 inch tall tire and a 410 is a option to lower cruising rpm s if a lot of e way driving is in your future
    My car is not used daily and not much e way either
