Results 1 to 17 of 17
Thread: Carb size
    Default Carb size
    Just wanting to get a few opinions, do you guys think a 670 CFM Street Avenger would be too big for my Cobra motor right now? I was looking at the 570 CFM but don't want to have to replace it after I modify my engine a little more, Holly States that the 570 is good for 300 horse, I thought it would be good for more than that. Thoughts and comments appreciated.
    Sent from my SM-G900V using Tapatalk
    May 2014
    Royal oak Mi
    should work well for mild 302 I had 670 on 331 had 650 dp on it before that I just cruised the car though
    A good friend of mine had 570 on 351 it was in a truck it responded well but was mild 351 with performer intake and a RV cam some other typical bolt on stuff it was responsive
    I like Holley carb because most any part store carries parts for them and gaskets..not that next day shipping is awful just nice to have parts in your hand before you lay down money
    Nice carb for the money but did have issues with the shiny finish coating flaking in the bowl
    my rear bowl was flodding so after I took it apart and cleaned it thoroughly I put new rear bowl on it and no problem since
    FEP Power Member blackgt85's Avatar
    Dec 2005
    Sussex, WI
    I had the Aluminum 670 Street Avenger and it was a nice carb until my combo wanted more... I'd recommend it.
    Justin
    Thanks for the replies so far! I really debated on a double pumper. ...but thought vacuum secondaries would be more street friendly
    May 2014
    Royal oak Mi
    for MPG efficiency the best your going to do in my opinion is vac secondaries
    you can always buy a tuned carb for track fun simple and quick to swap out when you set it to full kill or Saturday night
    you can find DP pretty cheap on Craigslist or similiar sites and most rebuild kits are 50 bucks for dp or so
    I have the 670 avenger on my Ford Racing 340 hp 306 and it was almost perfect out of the box. A couple of jet changes and it runs great. I would recommend it too.
    1985 Mustang GT 5speed LRB with Ford Racing M-6007-X302, Performer RPM, Holley 670 Avenger carb, BBK headers with H-pipe, B&M short throw
    1986 Mustang GT (parts car)
    1986 LX Coupe 4cyl, 4speed, LRB
    Ok guys, I am really leaning towards Holley's 650cfm ultra double pumper. If I am wrong for doing so please let me know. I enjoy tinkering with my car. I like the thought of mechanical secondaries. The car now is 84 GT 5 speed, 8.8 rear end, 93 cobra motor, cammed. Just a weekend car, not a daily driver. Just kinda a Saturday night/Sunday morning car. And eventually would like to end up in the 331 cubic inch engine size do I don't want to have to replace a carb again. Thoughts again please!
    May 2014
    Royal oak Mi
    Common rule is if it's a manual trans go with mechanical secondaries
    I'm using vac secondaries and like the MPG But sounds like that's out the window with your statement
    The mechanical secondairies can be very beneficial from a stop and clutch drop at ???? RPM
    The vac secondaries not so much but it has its place for sure
    All depends how often you want to put gas in it and both will work well once set
    Quote Originally Posted by Jerry peachuer View Post
    Thanks for the replies Jerry, and every one else! Ordered my 650cfm ultra double pumper last night. Actually took the 600 cfm edlebrock off the stang and put it on my 82 F150. It was previously a 2 barrel but needed a new carb anyway. Win win I hope.
    May 2014
    Royal oak Mi
    Good deal
    It has arrived!
    May 2014
    Royal oak Mi
    Liking the retro packaging on the box
    Nice
    Nice
    Got it installed, car fired immediately! Starts better than ever!
    FEP Power Member 83gtstang's Avatar
    Shreveport LA
    Cool, been a Holley man all my days as a car gear head. Wasn't until recently when I bought a car from an old friend, an 85 GT, that I fell for the Demon carberator.
    Got it installed, car fired immediately! Starts better than ever!*
    Did you have to change jets or just fine tune out of the box? I've got a Edelbrock 600 on my mild 351 and thought about switching to a Holley dbl pumper
    84 Mustang LX 351W
    Weiand Stealth
    Edelbrock 1406
    BBK Shorties
    O/R H pipe
    Super 40s
    8.8 3.27 gears
    May 2014
    Royal oak Mi
    Quote Originally Posted by 84T-Top View Post
    Glad to hear
    Quote Originally Posted by brian84foxbody View Post
    I had the eddy 600 on my car. ..I didn't touch the holley! Put it on, fired it up. That being said I have not driven it yet with snow on the ground. I bought the ultra, with an electric choke. Holley claims it comes wry flow tested and pre-tuned for the most part, fine tuning maybe necessary.
