Hi, I am new to the forum. I have looked over many of the past posts but still have some questions. I have an 81 futura that I am collecting parts for to convert to cobra brakes and MM bilstein coilovers. My main question is, should I use 94-04 arms to get optimum camber? One of the last items on my list to get are wheels. Wouldn't the 05+ mustang wheels with the greater offset be the "hot ticket" for keeping the tires under the fenders? I already have a wider 94 cobra rearend assembly. I have considered converting to stock fox width, but the diff is a 31 spline, so the cheapie aerostar axle swap does not apply, then I'd also be on the hook for some north brackets too. So for me, wouldn't it be a cheaper, balanced approach to increasing track all the way around, then correcting down with the new mustang wheels? Would I then have coilover clearance issues? Any help appreciated. Thank you, Chris
