... both for reliability as well as inexpensiveness...
OR, read on... ( * WARNING - not for the squeamish of EFI * (EFI guys, please help!) )
I don't have the time or the money right now to YANK all EEC-IV and put carb/pump/duraspark on this '86 CFI 3.8L V6, as has been in the back of my mind since getting this car. Anyway, it's O2's are now no longer "switching" when the car is fully warmed up, both staying at 0.90-0.95 volts, a tad rich, at ~14.45:1 at idle. (Open loop?) I know, a voltage reading at all from them means they're working, and the grounds are good, and that computer may not be adding/subtracting fuel, which is what makes O2's "switch" back and forth just above and below stoich 14.7:1 when in closed loop... my nightmare headache coming true, lol
Before I wander off like a chicken with it's head cut off buying oxygen sensors that maybe aren't needed....
Here are the umpteen checked and verified to this moment facts, if some of you fine folks here have some ideas for me:
- fuel pump working
- fuel filter good
- fuel pressure is at 40psi
- fuel injectors clean, not leaky/leaking, and both reading 2.6 ohms resistance
- TPS voltage is at 1.0 at idle and smooth with no drop-outs to WOT
- no vacuum leaks at/below throttle body or anywhere else (creating a vacuum leak sent O2's lean, normal)
- KOEO/KOER codes only about missing air injection (non-issue)
- cylinder compression tested and all six cylinders 145-165psi (continued head gasket coolant containment remains to be seen)
- replaced 195-degree thermostat recently, due to factory temperature gauge reading at the N
- cooling system burped and full
- temperature sending unit threads grounded (removed some teflon tape that was on threads)
- warmed it up real well and hoses hot, feeling like 195 to me, hotter than before
- thermostat not opening before it should
- factory gauge again reading at the N and lower (maybe a hint that it's remaining in open loop, never entering closed loop? But that's got to do with ECT, not the gauge sending unit... oh, mighta answered my own question there, lol... better check ECT voltages... crap, lol)
- car appears to run really well, with no rich stink or black tail pipe either...
I think that's everything (sorry about this long-winded post. I want to cover all bases, and I'm to get the car out of where it's stored, where I can work on it, tomorrow or very soon this week), but I'm hoping you might see something here (or not here) that I'm not seeing...
