Hey Everyone
I've been a long time lurker and decided to make an account to help show off my build. I'll start with the juicier stuff like my car.
1985 Ford Mustang LX Notch
As far as I can tell, it was originally a V6 auto car, judging by the pounds of wiring harness I have cut out to fix a butchered V8 5 speed swap. Still in the process of tidying it up but it's getting there. I limped it home with a spun bearing, pulled the engine three times since for different reasons.
SPECS
71Torino Block
E7 Heads with Dual Valve Springs
.513? Comp Cam (Have to check my card)
Edelbrock Torker 2 Intake
Edelbrock/Weber Four Barrel Carb (Has both Brands badging, if someone has any info on that I'd appreciate it)
New OEM Crankshaft
Melling High Volume Oil Pump
MSD 6AL Box
MSD Pro-Billet Distributor
MSD Blaster 2 Coil
Some Autometer Mechanical Guages
Stock Headers into Junk Exhaust
Unknown Springs Lowering springs with 250lbs QA1's in rear
KYB's in front, Rears are deaded
Little Bit of Wieght Reduction
Aluminum Radiator
Dual Electric Fans
New Brake Booster & Master Cylinder
Rust Repair on Strut Towers
7.5 Rear End w/ Discs from an New Edge (Why guy before me did that, I dunno)
Front rotors swapped to five lug with Ranger parts (This one was my B)
I'll post some plans and etc later.
