Results 1 to 3 of 3
    Default AC/Power steering Delete kit
    Ok I am Jennifer I have hijacked my amazing husbands sign on.. I qualify since my hands are greasy too and spent good part of the weekend under our 1984 FORD Fox body 20th anniversary edition.
    I am trying to help now that we have the timing cover and new water pump on. After 2 gasket changes and me taking out the pan bolts about 5 times .. I know my 1/2, 7/16, and 5/8 now oh and I got to use the good socket wrench. I was told I qualify for my own.
    Here's the deal.. We have a delete kit for removing the AC to eliminate extra weight.. If I had it my way it would have stayed but he won that one. We are keeping the power steering. So why are things not lining up? They are about an inch off? We have a new belt but not there yet. The pulleys just do not line what are we doing wrong?
    Please help
    David and Jennifer
    Feb 2009
    Snohomish, Wa
    Jennifer does your hubby know how lucky he is? If not... he should. If you can show us some pics of the misalignment it will help with the diagnosis.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Which pulleys are out of line?
