Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 76
Thread: 78: Big Red
  1. #51
    Apr 2010
    Portland, Oregon
    So what about those details on the taillight box?
    Too much heavy food at Gearhead Breakfast this morning: huh?
  2. #52
    Apr 2010
    Portland, Oregon
    Parts collected the other night. Although I'm won't be using some of these parts, they are NOT for sale (in this section ) because that would get me frowned at, probably spoken to , or even reprimanded
    ES headlights, grille & side mirrors:
    Name:  Parts haul 01.jpg
    ES blacked-out tail lights:
    Name:  Parts haul 02.jpg
    Looks like all of the "Exterior Accent Group Trim," don't know if any of it is useable:
    Name:  Parts haul 03.jpg
    Rear side vent pieces, interior & exterior. Standard on ES's, optional on all boxtops, I believe. RnD (RacinNdrummin) from whom the parts came from originally complained that they really leaked badly:
    Name:  Parts haul 04.jpg
    Lots of "stainless" (aluminum of course) upper trim:
    Name:  Parts haul 05.jpg
    More to come.
  3. #53
    Apr 2010
    Portland, Oregon
    Nice driver's side panel, with slight curling, MUCH better than the black one I picked up a while back:
    Name:  Parts haul 06.jpg
    With the unique (?) ES panel insert, matching, I think, the passenger side dash bezel:
    Name:  Parts haul 07.jpg
    Red parts:
    Name:  Parts haul 08.jpg
    Name:  Parts haul 09.jpg
    The surprise that might be worth the price of admission: E3DF/E4DF (depends on which part you look at) instrument cluster with a 140mph "Certified Calibration" speedometer:
    Name:  Parts haul 10.jpg
    Also included was the red carpet, sagging headliner, the dash hull that RnD painted black, sun visors, heater, a box of miscellaneous small part, etc.
    All in all, a good haul.
  4. #54
    I love that "engine turned" ES trim. Mine had the woodgrain that came with the 6-gauge dash though
    Soooo, are you going to tell me how you did the taillight box or not?
  5. #55
    Apr 2010
    Portland, Oregon
    Oh! That. PM coming.
  6. #56
    FEP Member Stormin' Norman's Avatar
    Jan 2008
    Winnipeg, Manitoba, Canada
    Wow! I'm restoring mine, again (did it 2007, but had a fender bender in 2010) and couldn't find any great pics of the front brake line locations (have to make new lines), after doing all my rear lines. Your project pics are outstanding. Thanks. Mine weren't all that well taken.
    Nice work.
    1979 Ford Fairmont 4-Eyed Squire (Mexican-Built) 3.3 I6 (200 CID) 4-Speed SROD Trans, Tri-Power
  7. #57
    Oct 2008
    plover,wi
    I remember doing some research about the ES fairmont stuff years ago, but never really noticed they had blackout trim on the taillights.
  8. #58
    Quote Originally Posted by rab View Post
    Indeed they do. If you ever want to talk ES, I'm your guy!
  9. #59
    Apr 2010
    Portland, Oregon
    Ah, good. I was hoping you'd see this, Brad.
  10. #60
    86 50CPRI
    Guest
    eager to see more...nice work
  11. #61
    FEP Supporter PROSTOCKTOM's Avatar
    Jan 2016
    Terre Haute, Indiana
    Mike,
    What year speedo and tach are you using? I want to convert my 80 Fairmont to a tach and 140 speedo.
    Thanks,
    Tom
  12. #62
    Apr 2010
    Portland, Oregon
    The cluster is out of an '86 SVO (note the turbo gauge in the upper left) with aftermarket overlays. You could/should substitute a V8 tach and amp gauge or put an 85/86 SVO speedo into a standard Mustang cluster. Check out:
    http://vb.foureyedpride.com/showthre...-into-fairmont
    http://vb.foureyedpride.com/showthre...airmont-Zephyr
  13. #63
    Jan 2016
    Thanks Mike, I'll read up on this.
    Tom
  14. #64
    Wow!! This project is truly inspirational. Great work!
  15. #65
    Aug 2012
    Mechanicsburg, PA
    What's the word on this Mike? Making smoke yet?
  16. #66
    Apr 2010
    Portland, Oregon
    Progress is being made in fits and starts, much of it correcting things done early that I was unhappy with.
    A report with pics coming soon.
  17. #67
    Apr 2010
    Portland, Oregon
    Wow! I've been working (occasionally) on Big Red for two years now. And no updates for a long time.
    She's been running for more than a year, but life gets in the way.
    Time to move her out of the shop, check the cooling system for leaks, then fill with 50/50 antifreeze, set the timing at running temp, etc.
    First time moving under her own power since I sold her in 2011.
    Quick video (I hope): https://www.youtube.com/watch?v=dq7LXSFT6tg
    Running a little rich, one lifter is ticking. Small stuff. On the road soon.
  18. #68
    Apr 2010
    Portland, Oregon
    Adding some missing stuff. Console details:
    Bare smooth metal.
    Studs welded to the back.
    Gauges mounted before painting. Eventually, I'll add a switch on the left for the 2-speed rear defogger.
  19. #69
    FEP Power Member Fearnot's Avatar
    Concord NC
    Sounds and looks great Mike! Thanks for the update.
    88 Turbo Coupe auto
    88 Turbo Coupe 5spd
    79 Fairmont Futura 4.6
    80 Capri 5.0/5spd project
    79 Pace Car 5.0/5spd project
    86 GT conv 5.0/5spd
  20. #70
    Apr 2010
    Portland, Oregon
    Disappointingly poor quality iPhone video.
    Boport 2.1 cam in between the too-close-to-the-exhaust microphone pftt pftt pftt.
    Ah, well, another learning experience.
  21. #71
    Concord NC
    But it's running and closer to the road.
    88 Turbo Coupe auto
    88 Turbo Coupe 5spd
    86 GT conv 5.0/5spd
  22. #72
    Apr 2010
    Portland, Oregon
    Default Prayers Answered!! ;-)
    After many, many long, arduous hours spent in fervent prayer to the great goddess Serendipity, she has answered my prayers.
    After a good shot of electronic contact cleaner, it reads 77ohms at bottom, 3ohms at highest and sweeps smoothly up and down.
    Oh, it was on RockAuto (1 available).
  23. #73
    Sweet!
  24. #74
    Apr 2010
    Portland, Oregon
    Uncle Barry famously said, "Change is good!"
    So be it. I have begun collecting parts for the next change:
    Name:  Intake detail.jpg
  25. #75
    Mar 2013
    Where the Navy sends me...
    Cool! Did you make that / have that made yourself, or where did you find that plate?
