Results 1 to 13 of 13
    Default Good Cam/Aluminum head combo?
    I'm looking for a good flat tappet and aluminum head combo for my 84 GT. I'm putting on a Weiand 8020 intake manifold soon, but i was wondering what a good cam/head combo would be to break 300hp. I want to be able to run it on 91 octane and not be too hard on the valves, but i'd probably get better valves eventually so thats not my main concern right now. Is this asking for too much from a flat tappet? It seems like people are absolutely disgusted by any 302 thats not a roller. Let me know what you guys think!
    May 2014
    Royal oak Mi
    Attachment 91080
    Here's 1 option it has 9-1 compression and its matched which is the single most important ingredient
    It's always hard to come up with the big stack of money to outright go this route and that's well understood but it's 1 of many options I bet
    Good luck
    FEP Member jsfrv6's Avatar
    Dec 2012
    Picayune, Mississippi 39466
    Those Edelbrock packages are pretty much full proof if you have the money....
    Look at my signature for my previous build. I used an old set of Edelbrock performer heads with the 1.90 intake a got off ebay for about $500 bucks. Had about 9.5:1 compression. Used a flat tappet Lunati Cam, a performer rpm and a 650 holley dp. It went 109 mph in the 1/4 which equate to about 320hp in a 3100 lb car...
    Heres the cam card.. One sweet little cam..
    Name:  Lunati cam card.jpg
    Scott
    Picayune,MS 39466
    Torch Red 2004 Mach 1 Mustang
    Silver 85 GT
    Previous set up...
    306, Lunati flat tappet, Eddy Performer Heads, RPM intake, Holley 650DP, Shorty Headers, Flowmasters, 3.73, T5. 12.92 @109
    Current set up,,,
    408w, Internally balanced Scat rotating assy, Comp Hyd roller, Brodix heads, eddy air gap RPM intake, PowerjectionIII EFI, Longtube 1-3/4 headers, Flowmasters, 3.55 Cobra 31 spline diff w/Moser axles, TKO 600 5spd, Mcleod dual disc street clutch... ET... Traction Limited 11.93 @120mph
    does it matter that that is advertised for an 81 or earlier mode?l or as long as I have a flat tappet am I ok?
    May 2014
    Royal oak Mi
    Hate to mislead you so I would call the pros at edelbrock or any after market manufacture you choose
    There are many options roller or non roller motor packages with proven results
    Get a set of these link bar roller lifters for your flat tappet block,some shorter pushrods and your good to go on running any roller cam you want. I've got a buddy running these in a 69 302 block that is a 331 and he turns it 7000rpm a lot with no problems after 2yrs of abuse. The best and baddest aluminum heads on the market now are the TrickFlow 190 11R's. Not cheap but they will make 350rwhp+ on a stock shorblock with the right cam all day. Another bonus running these heads is you can run a pretty big cam without PTV clearance. The price below is for one head at Summit.
    http://www.ebay.com/itm/For-Ford-302...906cd9&vxp=mtr
    http://www.summitracing.com/parts/tfs-52515601-c01
    i'm trying to stick with a flat tappet. http://www.summitracing.com/parts/edl-2091/applications i'm assuming this kit would work, but if it did, do you think i could even consider 91 octane?
    Dec 2012
    I used it in an 83 block and all is well.... I think a flat tappet block is a flat tappet block period...
    Scott
    Picayune,MS 39466
    Silver 85 GT
    Previous set up...
    Current set up,,,
    Dec 2012
    Scott
    Picayune,MS 39466
    Silver 85 GT
    Previous set up...
    Current set up,,,
    What kind of gas do you run? That part is key
    Dec 2012
    Quote Originally Posted by NewKidOnTheBlock View Post
    I was at about 9.5:1 and had to run mid grade 89
    Scott
    Picayune,MS 39466
    Silver 85 GT
    Previous set up...
    Current set up,,,
    FEP Power Member horsepowerjunkie's Avatar
    Jul 2009
    Juist outside Minot, ND
    This one should also easily make 300+ HP.
    http://www.summitracing.com/parts/ed...view/make/ford
    Plus they have a rebate for a free Carb! Buy a new Edelbrock Total Power Package Top End Kit get a FREE Performer Series or Thunder Series AVS Carburetor!
    11 GT Black, A6,Steeda CAI, SCT X4, Circle D 4C
    89LX Blk Hatch,363 Dart,C4,T76BB,FAST EFI
    86 Black GT, 331 Dart, S-trim aftercooled, 4R70W
    82 Carpi RS, 306, T5, 8.8 4.10's.
    72 Demon 340 4-speed(one of 1667)
    73 Dart Sport 340, 410ci, Indy 230cnc+, bracket brawler
    01 Ram Quad Cab, 5.9L car hauler
    02 Grizzley 660
    03 Honda VTX 1800
    I think the 367 HP kit speaks to me more
