    Default Proper Torque Settings - Main Cap Bolts
    Just started re-building my first roller 5L block and I have conflicting reports on the torque settings for the main caps.
    Initial findings show 60 - 70lbs for the inner main cap bolts and 35-40lbs for the outer cap mains from everything I searched. But then I have a ford book listing 351W and 302HO caps at 95-105lbs.
    What's the difference between the 302HO settings and the other settings?
    Aaron
    FEP Senior Member rob342's Avatar
    Aug 2014
    darien, il
    what's inner and outer? front and rear? either way, 35-40 for a main cap bolt doesn't make much sense if you think about it. does it? the only way you should have something telling you a lower value is if it's specifying using something like ARP moly lube. even then it would be only slightly less.
    81-95nm = 60-70ft/lbs
    122-142nm = 90-105ft/lbs
    maybe something you're reading is lost in translation? the image i clipped is from AllDataPro.com here at the shop.
    i have a 1992 GT, 4.10, 5spd.
    Quote Originally Posted by rob342 View Post
    I've seen a few sites like this one mention 35-40lbs for outer main cap bolts. They also list main cap bolts at 60-70lbs.
    http://mainemustang.com/mustang-info...t-torque-chart
    Feb 2009
    Snohomish, Wa
    The 35-40 would be for the Boss 302 blocks outer bolts on their 4 bolt mains.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Ok, makes sense now. Thanks.
