When I engage the clutch, backing up and also moving forward, I hear a squeaking sound coming from the rear of the car. It's almost as if the drivetrain being engaged is pulling on something, and the resulting strain causes a squeak or it could also be described as a groan. It's most notable when backing up with wheels turned, or going from dead stop while making a left or a right turn. A bunch of things come to mind; U-joints, differential fluid, suspension mounts, body mounts, etc. What would be the easiest thing to check first?
No stats here.., for shame
