I blew a cam in my built up 306 which in turn put metal all through my motor and destroyed some bearings. I'm looking at the CHP street fighter 347 short block with -14.2cc reverse dome pistons. Plan is for a street car that will be ready for boost when the time is right but not immediately. I am mainly looking for a list of all the parts from my previous motor that I can reuse because well its all money. Timing cover oil pan Msd ignition exhaust headers (hooker super comp) performer rpm intake 650 QFT CARB!? Looking at AFR 185cc heads and I'm not sure of a camshaft either. I think a safe 9.0-9.5:1 compression will do me well. On the motor alone ide be upset if it was less than 340 rwhp. So is the RPM intake and 650 carb up for the task? Some cam suggestions somewhere in the neighborhood of .570 lift will be appreciated. I do plan on porting the intake and heads but we will see about all that. I know its a lot of questions and information but I'm very excited to start this build. Does it appear I am going in the right direction?
