Drove my 86 GT the other day after it had been sitting for 3 or 4 weeks. Needle in temp gauge never moved, it used to come up and stay in the middle of normal range. Tried grounding the connector on the sender and the gauge pegged over to "H" so I think the gauge is supposed to be ok. Went and installed a BWD WT7245 sender and drove car again. Needle gradually moved up and then stayed around the "L" on the gauge after driving around town for about 20 min. Went back home and checked engine, not overheating or anything. Figured maybe bad or wrong sender so I put in a Standard TS274 and drove again, same thing needle hovering between the "L" and the white bar toward the "H". So Im thinking maybe something got stuck or clogged from the car sitting so I hooked up a manual temp gauge and let the car idle for a little over 30 min and it never went above 185-190 deg. which seems ok. So am I getting the wrong sending units not calibrated for the Mustang 5.0 or is it something else? Thanks
