Hey guys, I ran my 86 GT for the first time a few weeks ago. First run was terrible, second was a little better. But I feel my mph was low for the cars mods
This is my setup:
86 GT 5.0/5-speed
stock 89 shortblock (re-ring and new bearings)
96 explorer GT40 heads -F3ZE casting- with mild port and polish (cleaned up bowls, smoothed transition etc.) with Trick Flow springs
stock rockers
9333pt felpro head gaskets
TFS-1 Camshaft installed dot to dot
Edelbrock Performer EFI intake with Edelbrock 7220 gaskets
65mm explorer TB
67mm FMS egr spacer
Stock 55mm MAF
Motorcraft copper plugs
Ford Racing 9mm plug wires
Accel cap and rotor with brass terminals
Cold air intake with K&N conical filter in inner fender
Flowtech shorty headers, 1 5/8" primaries, 2.5" ball flange
off-road 2.5" H-pipe
Flowmaster 2.5 cat back
A9L computer
12* initial timing with spout removed
Taurus 3.8 electric fan ( with 3G upgrade)
Stock T-5 (3.35 first gear)
8.8" with 3.73 gears and carbon fiber clutches
225/55/16 falken street tires on pony wheels.
Car should be close to stock weight, has A/C, no smog, stock sway bars are on and hooked up, stock suspension with replacement shocks/struts.
Runs and idles good, no smoke, doesn't use oil.
Car was at operating temp ~180* at the time of runs with 1/2 tank of fuel and 215 lb driver
The first run was bad, I spun like crazy in 1st and 2nd, missed 3rd, and ended up with a 15.6 at 94.17
second run was a little better, not as much wheel spin, ran a 14.3 at 93.96
Based on what I've seen my friends cars do, and what I've read, I was expecting closer to 100 mph trap speed. Is that unreasonable?
My buddy has a 91 lx hatch, with nearly the same setup other than a b-cam, and he traps 102.
I did have to replace the battery before I went to the track, the car sat for a few hours with no power to the ECM, so it probably lost any data/memory it had from the current setup. Could this have affected my trap speed?
Any ideas on this? or am I asking too much from this setup?
here are the slips from the 2 runs.
