Page 3 of 11 FirstFirst 12345 ... LastLast
Results 51 to 75 of 259
Thread: The Phoenix
  1. #51
    Mike1157
    Guest
    Quote Originally Posted by 83zephyr4.6 View Post
    Attachment 91762
    Attachment 91763
    Progress has been slow recently. I've been working way too damn much. I finally managed to get the core support the rest of the way off. Also started buying engine parts.
    Those are a surprise that I should be able to start giving sneak peeks at next Wednesday. Any guesses??
    Uhh a roller cam for a 250 6 banger?
    A turbo?
    A mega squirt ecu kit?
    An Eaton blower?
    I give up.
  2. #52
    Quote Originally Posted by Mike1157 View Post
    A turbo?
    I give up.
    Haha pretty far off on all of them. I do have a real wicked cam for a 300ci 6 though.
  3. #53
    Ok so the parts started showing up today....so here is the first picture and should pretty much give it away.
  4. #54
    Ordered a few more parts. I'll post pics as they get here. Just waiting to hear back on the crowning jewel.
  5. #55
    That'll be so freakin' cool!
  6. #56
    More parts! Should be getting more tomorrow.
  7. #57
    Ok I can't help myself. This should be showing up next week. I'm pretty stoked.
    I've decided to sacrifice the AC in order to put the alternator where the compressor would normally be and save some money by not having to buy the timing cover and pulley bridge. As soon as I have all the pieces I will start fabbing up some brackets.
  8. #58
    More parts! Planning for future development as I call it.....ain't taking no chances.
  9. #59
    Apr 2010
    Portland, Oregon
    <cough> Fuel pressure regulator? <cough> Attachment 91987
    Just askin'.
  10. #60
    Haha. Yeah there will be one installed before the car even runs for the first time. I was thinking about using the stock marquis system as it puts out 40psi but I don't know if it can supply the volume. I'll probably use the stuff out of the Zephyr with a regulator.
  11. #61
    I feel like I'm 5 years old and it's Christmas morning. Got a couple side jobs to tie up then I'm going to strip the Zephyr finally and start building a mild monster that will over time evolve into a snarling, whining, ground pounding scary monster. I'm probably going to make a lot of progress a lot quicker until it is finally between the shock towers because I want to know what it will look like.
    I'm hoping to sell my 55 Ford pickup tomorrow that will help fund this project.
  12. #62
    Moved the car up to the other shop to pull the frame rail. Also took my spare Mark VIII motor up so I can build the supercharger motor.
  13. #63
    That's it for now. Time to order more parts. Think I'm going to go with main studs.
  14. #64
    Mike1157
    Guest
    Teksid block........
    I'll keep suggesting this to you wagon guys till one of you decide to do it.
    Hack off the 4 door, be the only guy on the planet to graft the fairmont door frame onto your wagon and make yourself a fairmont version of one of these.
    Then you can either shorten (section) the entire body down to accommodate the coupe distance between the rear door edge and the front of the rear wheel opening, or leave it as is, and weld a modified cut down rear door shut where it'll look like what the falcon has going on in the above pic.
    It's gotta be a similar chassis mod when they did the Durango.
  15. #65
    Like this?
    That would be totally bitchin but it's way more wok than I want to put into my $280 wagon. Though if I could find a falcon like you posted there is a 427 looking for a home....
  16. #66
    Mike1157
    Guest
    Like this?
    Whatever are you taking about???
    You've cut the front off of it, and are stuffing in a supercharged, 4 cam mod motor. Most people consider an intake manifold and cam change on the engine that's already in their cars a lot of work.
    Let's check out the previous project......weren't you the guy that grafted a different front end on the last car, and went as far as modifying the radiator saddle,the fender mounting points, and then changed the entire cowl?
    Was that a 250.00 car before as well?
  17. #67
    You have a very valid point. It's just a whole different relm of body work I have yet to even begin getting into doing. (I'm only 24 for crying out loud, haha). I don't know if I'm ready to cut a car in half just yet. I would love to do a 2 door but I think it is still a few years down the road for me.
    Also the previous one was $500....like it makes a difference. Haha
  18. #68
    Somebody posted a 2-door wagon where they used the boxtop doors. I like that one a lot better.
  19. #69
    Aug 2014
    South Boston, Virginia
    Very cool build man. What trans setup are you thinking?
  20. #70
    Quote Originally Posted by FUKAZ28 View Post
    A 5 speed for now as its what I have. I would love a 6 speed but that is a future upgrade. Also plan on IRS sooner than later.
  21. #71
    More parts were waiting for me when I got home! Unfortunately the flow is going to stop for a while as my POS 6.0 ate it's fourth high pressure oil pump yesterday. Time to fix it and trade it in for a newer one with less miles. Hopefully can get back to buying Mercury parts soon!
  22. #72
    Got rid of the knock sensor bosses and made sure everything fits right before I have the block tanked.
  23. #73
    Aug 2014
    Looking good.
  24. #74
    Mike1157
    Guest
    Are you aware of the hot spots that exist between the 7/8 cylinders related to air pockets, and or lack of coolant movement on this engine? If not, look into the kits that are out there to help solve that problem.
  25. #75
    May 2013
    Berea Ohio
    Excellent advice, and the Marauder forums are a great place to get info on this fix.
