Results 1 to 7 of 7
    Default Early clutch release..What is the cause?
    My clutch now releases very close to the floor. I didn't adjust anything on clutch etc..I installed an aftermarket mechanical temp gauge on 1985 Capri RS. I know this should have nothing to do with clutch, but I don't know if maybe I unintentionally hit something while trying to feed temp gauge line through firewall or maybe bumped the clutch cable, but I don't think I did. But this did not start til after I installed temp gauge. This may just be a coincidence that it happened after that. Does anyone know what I should check because I don't think the clutch should engage and disengage that close to the floor. Thanks for any and all help.
    Most likely you need to adjust your clutch quadrant on the clutch pedal itself.
    Grab the clutch pedal itself inside the car and pull up on it as high as it will go. That should reset the quadrant and pawl to a new position and provide for a better release of the clutch.
    Good Luck!
    Trey
    Jul 2010
    Houston (Clear Lake), Texas
    I would take a quick look at the quadrant prior to adjusting like Trey speaks of just to make sure the plastic teeth aren't damaged.
    HAD
    HAVE
    I say go ahead and get an aluminum quadrant and firewall adjuster, and use those with your original cable. Hopefully it will be fine after the pulling up on the pedal, but I'll bet that it's only a matter of time before it starts to malfunction again. A decent aluminum quadrant and firewall adjuster should be well less than $100.
    These cars use plastic 'gears,' actually called the pawl and quadrant, for the clutch pedal height adjustment mechanism, and they are easily stripped. I'm somewhat amazed that some of them survive as long as they do, but unfortunately, the pedal shaft assembly (which is some thick metal) bends over time and spreads the pawl and quadrant apart, causing them to be more easily stripped because of less material engaging/meshing.
    Dunno if the dealer still sells new pawl and quadrant assemblies, but I've bought them before, and they come with a whole new pedal shaft. They weren't much cheaper than the superior aftermarket pieces.
    thank you all. I was able to rest quadrant by pulling back on pedal. I am going to put an aluminum quadrant and firewall adjuster on as suggested. Thank you all.
    reset not rest.
    Only get the firewall adjuster if you're going to get an aluminum quadrant to use with it.
