For sale is our 1986 Mustang GT drag car.
Weighs 2685 with driver.
Ran a best 11.36 with this setup.
Has an 8 point roll cage,subframe connectors,
and torque boxes have been reinforced.
Adjustable upper control arms
Tubular UPR k member with coil overs.
15 by 10 back rims with 29 by 9 Hoosiers
15 by 3.5 with MT front runners.
There is a 5 gallon fuel cell with an aeromotive pump.
The rearend is an 8.8 with 4.56 gears, a spool with
33 splined axles, and 9 inch ends with disk brakes.
4 lug with 5/8 studs.
Transmission is an AOD with parts from Lentech.
OD bands have been removed. I maually shift it at
6000 rpm. 2800 stall convertor.
The motor is a 347ci sbf. 10.5:1 compression.
Roush XL220 series heads, some porting by Jerry Arnold.
Mild Comp Cam(intake:224@50, exhaust 234@50).
It is a hydraulic roller. HD Ford Racing lifters.
Scat forged crank, with eagle rods, ans a girdle.
Trick flow intake. 75mm throttle body, 30 pound injectors.
1 3/4 long tube headers.
Asking $8800 OBO
Call(616)218-7252
