I finally got around to pulling the throttle body today. I took the fuel injectors over to a local guy that flow tests and cleans them. Ill have them back in a few days.
I bought a rebuild kit from Standard Parts and it comes with everything as well as great instructions and diagram. One thing is the main gasket that goes on the bottom of the throttle body is much too thin. Im gonna have to reuse the original.
Attachment 88506Attachment 88507
Im wondering if I can, or should use the two paper thin gaskets on top and bottom of the original one?
Also, I picked up a Standard fuel pressure regulator and it doesn't look the same as the Bosch that came out of the unit. Should I use the new one? Put the old one back in? Or try to find an original Bosch? The number on the Bosch is
0280 160 211
E0SE 96968 AC
443 B
Attachment 88508Attachment 88509
Googled and found nothing on those numbers.
The numbers on my fuel injectors is E4ZE-CA
Seems very generic, cant find specific info on the injectors either. I was hoping to locate a new pair or NOS as backups.
