Hey guys, what's a common indication of the wastegate actuator when it fails? I have a vacuum/boost gauge drilled and tapped into the compressor housing. It is putting out about 5lbs pressure when I got into it pretty hard a few minutes ago.. Does this mean it's still good? OR could it also be ruptured a small bit and causing a minor issue like a vacuum leak problem even when idling ????
