Hey guys, I have a question on what you are all using for harmonic balancers. Upon further investigation, my buddy and I determined that I have fell victim of the moving outer ring. We checked it again today after the car started tripping over itself and found my initial timing way off. We set #1 piston at TDC by a gauge and afterwards set the initial timing at 10 BTC. We are showing 10 BTC at idle and 25 at around 2500 rpm. Does that sound right? I still think the outer ring is moving a bit as it shows melting around the damper. I would like to get the best part and get this set correctly.
