i have a question. I changed out my carb to a holley 4160c (already had a aftermarket carb on it), the problem now is that after hard acceleration when you let off the gas it back fires through the exhaust. I want to know if you have to change the intake also when using a different carb. I think it's pulling vacuum under acceleration. If I need to change the intake what is a good option, the engine is original and still stock.Thanks
