I just picked up a used Hurst Comp Plus shifter for my 85 and I notice it has a lot of dirt and other crap embedded in the grease that's found at the base of the gear stick and the underside where the gear sick comes through the shifter base (right above the ball that mounts the shifter to the trans). Can this be cleaned out and re-greased? If so, how do I go about making sure I grease it enough and what grease do I use?
These shifters come with a boot that typically protects theses parts from dirt, but with mine being used it didn't come with this boot.
Also, when I look into the area where the shifter meets up with the trans (that square area that's exposed when the shifter is removed) is ther supposed to be any oil or grease inside or should it be dry?
Thanks!
