I'm needing a little help with my 85 Mustang GT. I drive the car maybe once a week and it is all stock, I replaced the starter solenoid thinking that was the problem, before replacing it the car would do a hard clicking sound as though the battery was dead, but it is not. I just replaced the starter solenoid and it cranked right up and started, I turned it off, tried to crank it agian and it gave me the same hard clicking sound. So basically after I start the car and turn it off I have to disconnect the battery every time in order to start the car back up. Almost as though it "resets" when I disconnect the battery. After disconnecting and reconnecting the battery the car fires right up immediately, battery is strong, it is a stock Holley 4 barrell and honestly it starts a lot faster than my newer FI cars but only I disconnect and reconnect the battery. Need help being pointed in the right direction as to what this could be, I get a clicking sound almost as though it's coming from inside the glove box. I wired up the new solenoid just like the old one that was on there, one post at a time until I switched everything over, the only thing I can think of is the original solenoid possibly was wired up incorrectly to begin with or it's something else in the car not working. I would appreciate any help please, thank you.
