The fact that you are reading this indicates that, to some extent, you are likely interested in restoration or detailing of our beloved four eyes. I certainly do enjoy seeing the efforts of others, and I have learned a great deal from this sub-forum. So in the spirit of restoration, I have some pics to show you.
I first did suspension/undercarriage detailing three or four years ago, so it was time for refreshing and upgrading. The upgrading was based on things I have learned from seeing a couple low-mileage and/or unmolested cars over the past year, plus pictures posted on this forum. So, a few weeks ago I decided to rework the floor pan areas.
About the time I got started, the "76 mile Pace Car" pictures showed up. (Thank you Sandy for making them available, and thank you David for posting them). This car is terrific. There were details I had never seen or even thought about. So what started out as floor pan work, mushroomed into refreshing of certain front suspension parts. It was one of those situations where you work over one part, and that makes the neighboring part look bad, so you do it too, and so forth. We've all been there, right? I've come to the conclusion that underhood and undercarriage detailing is a never-ending project (ha).
So, given all this introduction, here are pics of a few of my recent attempts at upgrading.
Fuel line taken down to bare metal, clear applied; brackets given same treatment; screws are likely supposed to be zinc dichromate, for now they have the Eastwood simulation treatment. Formerly I merely had it all painted black. Floor pans painted Eastwood Chassis Black Satin.
Check out the yellow stripe on the back of the control arm mounting bolt. I could not see evidence on my car of this stripe, but who knows if it was originally there. This was a "76 mile Pace Car" detail.
Much of what you see here was already done, but some areas/parts were freshened up. Check out the yellow stripe, in this case I could see evidence. These little details are fascinating to me.
Looking back towards the transmission. You can't really tell, but most of the suspension bolts were taken down to bare metal since they appear to have had no coating or finish. I then applied a thin coat of oil, just to keep them from immediately starting to rust (which is what they would probably do, here in the constant high humidity of Houston).
The passenger side.
(The pink in the pictures is reflection from the red towel on the floor. It is hard to take pictures of the undercarriage of a car!)
Probably the weakest front-end part detailing is the steering rack. It was replaced in 1999 and was/is painted all black. The "76 mile Pace Car" rack doesn't look like this. I am thinking about how to do an upgrade....
Now, overall I will admit the pictures make things look better than they really are, as is typically the case. If you were looking at it live, you could tell that certain parts and surfaces reflect that the car spent its first few years in the Rust Belt as a daily driver. For example, areas of the floor pans could be shined up like new, and other areas--- not so much.
Always interested in comments and suggestions for further improvements. I have more work to do before next month's MCA show in Loveland, CO .............
Bob
