Results 1 to 20 of 20
    Default Pls help 86 mustang 5.0 overheating with a full overflow no leaks in hoses
    Hello .. I just bought a mustang convertible 5.0 302 and it doesn't always overheat I though I was good until 3 hours after driving I noticed my coolant comming out and I checked the hoses they are dry and the overflow is full every time .. I have heat.. There are no leaks. But its obviously is leaking somewhere. I replaced the cap.. I drove last night this morn and it was fine again,all of a sudden it back to this
    It's probably the radiator, based on my experiences, but there are some tests you'll need to do, to narrow it down/rule it out.
    FEP Senior Member rob342's Avatar
    Aug 2014
    darien, il
    could be ANYTHING on a car you just bought. i would suspect it could possibly be a sticking thermostat, the fan clutch slipping too much, a missing fan shroud, or possibly but less likely IMO, a plugged radiator.
    since the car is new to you, you might start with the thermostat as it's the cheapest. i like "stant super stats"
    part numbers for those thermostats:
    195° stock thermostat: http://www.summitracing.com/parts/snn-45359
    180° perf. thermostat: http://www.summitracing.com/parts/snn-45358
    i use the 180°.
    __
    i can't recommend a fan clutch, but here's a little fan clutch reading material: http://troubleshootmyvehicle.com/gm/...g-case-study-1
    changing the fan clutch definitely wont hurt and wont break the bank.
    __
    i have also upgraded to this radiator and put an electric can from a nissan sentra on it. i beat the piss out of my car on 95° days with the AC cranked days without going over 1/2 way on the gauge. this would require a little thinking though.
    griffin USA made radiator: http://www.summitracing.com/parts/gri-1-26272-x
    fan upgrade process, parts list, instruction, links, etc: http://sbftech.com/index.php/topic,36684.0.html
    i have a 1992 GT, 4.10, 5spd.
    +1 for starting with the thermostat
    Jan 2014
    Arlington, Texas.
    It seems to happen a lot to new Fox owners. Is there an air pocket in the upper hose?
    OK I just did the thermostat ..even replaced the housing ... I'm letting it dry over night and see how it does in the am.. (Which I am still starting with the screwdriver/cillinoid) that's my next problem.. Replaced fuzes and the cillanoid and it still won't start from key. Ugh Thx for your help. I'm hoping the thermostat does it for this ..
    FEP Power Member 83gtstang's Avatar
    Shreveport LA
    Be sure your run the car for a while with your heater on and maybe your radiator cap off until the system burps. Hopefully that's all it is. Does it overheat when you run it hard? Definitely a new clutch fan could help. I had a blown head gasket and my car would overheat like that when I got on it. Do you notice a coolant and vapor coming out of your exhaust?
    Shreveport LA
    As for the key not starting the car, could be a bad ignition, or a open wire going to the start on the solenoid. Make sure it's connected correctly. I accidentally connected by battery terminal with the key on one time, it burned or popped a fuseable link in the wire. I ran a new wire from the column, spliced it in and it started everyday for ten plus years now.
    Check your clutch switch, or neutral safety switch.
    No key start - I had to replace the ignition module located in the steering column on my '86. Very inexpensive part. The two halves separated and all electrical contact was severed. Easy fix.
    No coolant comming out of the exhaust .. No clutch fan electric fan instead. The way I bought it
    Thank you about the ignition problem..
    The thermostat didn't work. We burped it and the temp was up to 280 and we shut the car off when it was done burping .. It made a noise also when it burped..
    The thermostat didn't work. We burped it and the temp was up to 280 and we shut the car off when it was done burping .. It made a noise also when it burped.. It took a hour this morning before it got hot and overheated. And the temp then was as high as it could go.. And when I bought the car Friday I drove it 3 days 90 degree and it was perfect .. All of a sudden I had to start it with a cillinoid and the next morning overheating .. Ugh
    Aug 2014
    darien, il
    Does the fan come on? If so, when? Can you post a pic?
    Jan 2014
    Arlington, Texas.
    You can burp it all you want but if you didn't fill that top hose with coolant, pinch it and quickly put it back on the radiator you will still have an air pocket in the top hose. That hose has to go vertical up and over the alternator, then down to the thermostat. Just filling the radiator after a thermostat replacement won't cut it. It could be another problem, but check this first.
    What is your antifreeze/water mixture right now?
    Should not be more than 50/50 antifreeze to water if not 30% antifreeze to 70% water this time of year. You don't state where you live, but based upon the 90 degree temperature when you bought it I am going to guess at least not up North.
    Check your initial timing and your timing advance as well to make sure you don't have an issue there.
    I would recommend replacing the ignition switch down on the column. Most likely that will solve your no start with the key issue.
    Trey
    FEP Power Member Ltngdrvr's Avatar
    Southeast Texas
    #1, please spell solenoid correctly!
    #2, bypass hose in place?
    #3, and it has been asked, what is the fan doing when it gets hot?
    #4, as to purging the air, I always jack the front of the car up as high as possible to help get the air out and coolant completely filled. In other words, make the radiator cap the high point in the cooling system to let the air escape.
    Oh, and exactly what does it do when you turn the key, just nothing or does it click or what?
    1979 Zephyr, EFI GT40P 5.0, Mac longtubes, Dynomax exhaust, AODE transmission, 3.27 geared 8.8, subframe connectors, Lakewood uppers/lowers, trunk mounted battery, fuel cell >
    < My Photo Galleries: http://s474.photobucket.com/user/Ltn...?sort=3&page=6
    More GT40P info than you ever wanted to know...http://forums.corral.net/forums/show....php?t=1014187
    And make sure your fan is pulling cold outside air through the grill and through the radiator.
    I have seen before, not on a Ford, but the water pump impeller is loose on the water pump shaft. Or the impeller has basically fallen apart. Is the radiator inlet temp warmer than the outlet? Enough heat transfer? Agree with possible air stuck in the cooling system. If its getting to 280* be careful you dont damage the engine!
