Results 1 to 25 of 47
Thread: 85 Coupe Redo
    St. Louis, MO.
    Red face 85 Coupe Redo Painted
    So just like my 88 vert redo it's all about a small budget. First thing is keep it road ready during the redo (driving build) till next year and then the heart transplant............V8 w/AOD or Turbo 4 w/5-sp.......
    Did installed a new fender today.
    Also removed the starter from the 2.3, it locked up on me twice so time for a new one.
    Scotty
    Past Pony's.....
    I'll be watching. Your front suspension sure looks clean, considering that you live in the snow belt.
    St. Louis, MO.
    Not sure about the previous owners but I've gone through 3 winters so far. There are more spots of rust here and there but this fender had to go.
    Scotty
    Past Pony's.....
    St. Louis, MO.
    I'm considering a 351w next year.....
    Scotty
    Past Pony's.....
    St. Louis, MO.
    The only upgrade for the interior is new carpet so it will stay much like this, keeping the rear seat, the upholstery, head liner are in perfect shape. The rear deck will get new carpet and I'll tint the rear window.
    I did add a 50 Years hat pin to the dash, I cut off the pin and used double sided tape,
    Scotty
    Past Pony's.....
    St. Louis, MO.
    Small update.....I need plates!
    But to pass inspection I needed to change all the front brakes including hoses and hard line, bearings.....etc.....
    and the boring rear drums including wheel cylinders, rear hard lines OK.....whew!
    Will have photos of "body work to do" later.
    Scotty
    Past Pony's.....
    St. Louis, MO.
    Other than the typical small bubbles of rust in the usual places looks like I might have to replace the rear bumper cover due to exhaust getting loose and melting it. I thought about cutting the bottom part off and replacing it with a 87-93 bottom to keep the trim the same. That seems like a lot of plastic welding to me though.....
    Tip....when removing trim to do body work put the nuts back on so you know where they are.
    I will paint under the trunk lid and the hood this time.
    Scotty
    Past Pony's.....
    St. Louis, MO.
    One upgrade and one replacement. Since the 85 2.3 came with no rear sway bar, got one at a JY, some sanding and a lick of paint and should be good to go. And the new front struts (same series I installed on my 88 5.0, gives very nice ride) should eliminate the bouncy ball I get over humps and bumps.
    Scotty
    Past Pony's.....
    FEP Member 86foxvert's Avatar
    Mar 2010
    Lake Worth, Florida
    Sweet ride....keep the pics and updates comin
    St. Louis, MO.
    Quote Originally Posted by 86foxvert View Post
    Thanks!
    Painted the sway bar today.....
    Also bought a rear bumper cover off EB for $100 shipped, it's in great shape.
    Scotty
    Past Pony's.....
    St. Louis, MO.
    Ahhhh.....Much better!
    Scotty
    Past Pony's.....
    FEP Super Member tORMENtOR's Avatar
    Oct 2007
    Bethlehem,PA
    Looking good!
    St. Louis, MO.
    Thanks! Updates to come as I have 3 full days next week on my stay-cation for the coupe.
    Scotty
    Past Pony's.....
    Aug 2014
    South Boston, Virginia
    Very nice, who made that dash pad?
    St. Louis, MO.
    Quote Originally Posted by FUKAZ28 View Post
    Dash pad is just a cover I bought from CJ Pony..... http://www.cjponyparts.com/dash-pad-...-1986/p/PAD6C/
    Scotty
    Past Pony's.....
    St. Louis, MO.
    Rear sway installed.....rusty diff will be addressed next spring.
    Scotty
    Past Pony's.....
    Feb 2009
    Snohomish, Wa
    Check your rear u-joint. It appears to be leaking some grease.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Mar 2010
    Lake Worth, Florida
    Progress ..... Its great and what a difference the bumper cover makes.... keep up the progress
    St. Louis, MO.
    I changed front/rear a year ago, hope they are still good.
    Scotty
    Past Pony's.....
    Jan 2011
    China Grove, North Carolina
    Hey, I just noticed that you're on modelcarsmag.com. Happy birthday!
    St. Louis, MO.
    Thanks! I have the day off from work, taking the 85 out & about to test the new front struts I installed yesterday.
    Scotty
    Past Pony's.....
    St. Louis, MO.
    New tie-rod ends installed today, my arms are tied.....LOL
    Scotty
    Past Pony's.....
    St. Louis, MO.
    Not much to report except LMR has there door weather strip kit on sale so I bought a pair (and a pair for the 88 as well).
    Scotty
    Past Pony's.....
    Nice. You're not alone with the small budget thing. Keep up the good work!
    St. Louis, MO.
    Moving in June, have to get on this paint.....replaced the other front fender.
    Scotty
    Past Pony's.....
