Results 1 to 11 of 11
    Feb 2012
    Elizabethton, TN
    Default Request Buck and VIN decode 82 GT
    I copied the Buck info but have since replaced it but most is out of sight so no picture. I did get the door tag picture.
    Mustang
    161775 61B F TR 057
    1CC DF ST
    LL AC 08 HB S
    GT MOD 05 V
    -D NLR
    How many miles on the odometer?
    Does this GT have any of the following options?
    cargo area cover
    factory wheels: 14" '16-slot' or TRX
    front license plate bracket
    leather wrapped steering wheel
    premium sound system ("AMP PULL" knob to left of radio, amplifier under center of dash pad)
    tilt steering wheel
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Feb 2012
    Elizabethton, TN
    cargo area cover
    premium sound system ("AMP PULL" knob to left of radio, amplifier under center of dash pad) It does show Premium Sound
    tilt steering wheel
    I'll look for the mileage.
    Has brackets for the cover but cover is missing
    Not sure on the wheels, it has later model 5 spoke.
    It had the front license plate.
    Not sure on the steering wheel as it has a fugly Grant GT. The car had cruise at one time but missing most of the components.
    Dash shows Premium Sound. Have not seen the amp but I'll look.
    Car also has intermittent wipers and rear defrost.
    It also looks to have leather seats, leather inserts with vinyl sides.
    That car's DSO is Cincinnati. Ohio has always had front plates. Mine was about 6044 cars behind yours on the assembly line, and I found buildsheets under the carpet in front of the driver seat, and inside the passenger side rear quarter panel, up in the C-pillar area. That will say which wheels it came with. I'm betting on TRX. They were more common, and yours is a fairly well optioned car.
    Cincinnati DSO covered areas outside of Ohio.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    VIN
    1FA = Ford vehicle manufactured in USA
    B = active belts, no airbags
    P = passenger car
    16 = Mustang 3-dr hatchback
    F = H.O. 5.0L V8 engine
    X = VIN check digit
    C = 1982 model year
    F = Dearborn Assembly
    161775 = 61,775th 1982 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 02/82 = February 1982 scheduled build
    F0008 = 8 lbs front accessory reserve load
    R0092 = 92 lbs rear accessory reserve load
    Exterior Paint Colors - 1C = Black
    DSO - 47 = Cincinnati district sales office
    Body - 61B = Mustang 3-dr hatchback
    Int Trim - ED = leather seating, low-back front buckets (E), Medium Red interior trim color (D)
    A/C - A = manual air conditioner
    R - 4 = AM/FM stereo radio
    S - D = T-roof
    Ax - Z = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 4 = manual overdrive transmission (Tremec 4-speed 'SROD')
    PP = front springs
    NN = rear springs
    Buck Tag
    MUSTANG = Mustang model line
    TR = T-roof
    057_ = body & paint rotations #057_
    1CC = Black exterior paint color
    DF
    ST
    LL = liftgate louvers
    AC = manual air conditioner
    08 = rear glass w/ defrost, hatchback w/ louvers and three-piece spoiler
    HB = heated backlite (rear defrost)
    S = speed control (cruise control)
    GT = GT model/trim level
    MOD = manual overdrive transmission (Tremec 4-speed 'SROD')
    05 = forward-facing hood scoop
    V = visibility (light group)
    -D = Medium Red interior trim color
    NLR
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Feb 2012
    Elizabethton, TN
    The car has been taken good care of in spite of being raced often. The carpet and seats will be removed for final cleaning and carpet replacement in the near future. Anyone good at rebuilding T-Tops?
    FoxChassis, thank you for the information, that's a lot to digest. Is there more information on what the CAT trim included? Maybe I should spring for a Marti Report?
    Sorry, was in a hurry when I decoded and posted. It should have been "GT", not "CAT". Correction made above.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Feb 2012
    Elizabethton, TN
    That's ok, happens to us all at times. Thanks again for your help.
    Wow, this is a nicely optioned car!
    1985 Mustang GT convertible triple white
    Stock survivor
    Feb 2012
    Elizabethton, TN
    Ordered a Marti Report for this car:
