Results 1 to 6 of 6
    Default left marker light out
    hey guys i finally got around to making my car legal and i have an electrical issue. my left front marker light doesnt work. im no electrical wiz but im pretty sure its a ground issue. can anyone tell me, or have a picture with the ground locations for the marker light circuit? ive searched but schematics dont really help me. its an 85 gt. thanks in advance.
    Probably on the radiator support. Are you sure the socket is OK? I think the socket pigtail only runs a few inches before connecting (plugging in) to the light harness. You could check to be sure it's connected...
    FEP Power Member 83gtstang's Avatar
    Shreveport LA
    Should be a small ground and screw on each corner of the radiator support near the lights area near the rubber adjustable hood stop. Spray the socket with WD40 if it's got corrosion in the socket. Use a multimeter or light test probe to see if you have current 12v at the socket or connector.
    Changed the pigtail. No change. Circuit tester lit up but the bulb wouldn't. I went over all the ground locations and cleaned the battery. Bulb lit up. Just weird that one bulb wouldn't light up. Now it's time to upgrade the alternator and relay the headlamps because I can't see anything at night. Thanks for the input.
    Feb 2009
    Snohomish, Wa
    Check the bulb socket. I had one the ground tab inside it broke off.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    The marker lights run off the same feed as the parking light filament in the combination parking/turn signal
    light. And as mentioned, all the front lights on each side share a common ground, at the top of the radiator
    support. One on each side.
    Cheers,
    Jeff Cook
