Results 1 to 19 of 19
    FEP Member shuffln's Avatar
    Jul 2013
    Hamilton Ontario Canada
    Default speakers in kick panels
    anyone added speakers to there front kick panels. i know the the dash speakers suck and i don't want to cut up the door panels so i was thinking of adding 5 1/4" speakers in the kick panels.
    1976 II coupe, 1982 GT, 1986 LX
    Check out the second pic in this thread. This Cobra has some sweet kick panel speakers:
    http://vb.foureyedpride.com/showthre...ED-ADVICE-HELP!
    Cheers!
    Mike (TopGear85)
    Have:
    Had:
    79PC-San Jose #2890
    90GT-Oxford Wht,5spd
    Jun 2013
    San Diego, Ca.
    Quicksilver has a badass set up in his kick panels. Gotta look close in the pics. I'm waiting on info from him about it.
    conmech - aka Marshall
    Aug 2004
    California
    My 86 is so far from original, I just added speakers to the door panels- custom based upon the 87+. Requires a little build out unless you want to move the window track.
    Jul 2012
    Georgia
    Another option is to replace the speakers in the dash, new speaker tech allows you to put a lot of power through those little speakers. I replaced mine and the ones in the rear panels in my convertible and they sounded pretty good. Well, as good as you can make a stereo sound in a convertible...
    May 2002
    Wareham, Massachusetts
    I'm going to change up my front speakers so that I have 5-1/4" woofers in my kick panels and tweeters up in the dash pad area. The units I'm going with are Kenwood KFC-P509PS. I will have to make 1/4" plywood circles that are the same opening as the 3" holes in the dash, cut a smaller hole through them and install the tweeters into those. Then I'll screw them to the dash like the factory had their speakers.
    http://www.kenwood.com/usa/car/speakers/kfc-p509ps/
    Here's a pic of the complete setup that I'll be buying.
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    420 rwhp/380 rwt (New Motor)
    11.49 @ 121.86
    306/T-5/4.30's (Old Motor)
    307 rwhp/278 rwt
    12.38 @ 111.38
    Newer dash speakers do sound a lot better but they are still pointed right at the windshield. I made some kick panels for the 85GT I had with some 6.5" separates and it sounded great. Just took a little time to fab up the kick panels. I've heard the Q-forms premade kick panels for the 87-up cars work in 79-86 cars with minor mods too.
    86 Notch under construction
    2011 4Runner Trail edition
    2014 Suzuki V-Strom 650
    FEP Member Mentok's Avatar
    Mar 2010
    Portland, Maine
    Quote Originally Posted by 85GT-79FJ40 View Post
    I've been wondering about the aero q-forms myself. That appears to be what quiksilver did. The q-forms were available for the foureyes up until about 2000. Would love to get my hands on a set.
    owner of the 666th mercury produced in 1983.......neat fact! black on black 5.0 t-5 capri with no other options but fishnet seats.....coincidence.......perhaps
    Jan 2007
    Quartz Hill, California
    I filled the 3.5" space in my dash with some Rockford Fosgate 3.5" speakers on 40 watt deck power and then built 2 custom 5.25" boxes to put in front of the drivers and passenger seats running on amp power. I didn't want to ruin my door panels way back when. System sounds killer! The only problem with the speakers mounted in front of the seats is you can't adjust the seats forward, which for me isn't a problem. I'm 6'3" and no one drives my car but me LOL!
    Robert
    My RS in Action
    May 2002
    I ended up buying those front speaker components (Kenwood's KFC-P509PS) that I posted above and they work really well. I decided to mount them in the kick panels because I didn't want to ruin my door panels. It's also easier and cheaper to replace the kick panels as they are now reproduced at a reasonable price.
    I had to make a 1/4" spacer to go behind the kick panels as these speakers were "thicker" than my old ones. I then painted the silver plastic covers and speaker grilles with Krylon's "Satin Black" paint to blend them in. From there I tackled the front dash speakers. Since I only had a 1/2" tweeter and my holes were 3", I knew I would have to fab something up. I took the original crappy Ford speakers and cut the entire paper cone out. I then noticed that the magnet was held on with 4 rivets. I drilled those out and knocked the magnets off. From there, I enlarged the hole in the center so that I could drop the tweeter directly into the center of the frame. Since the brackets to hold the tweeters were too flimsy for my liking, I took some construction adhesive in a caulking tube and laid a nice bead all the way around, then dropped the tweeter's frame into it. Once hardened, I re-sprayed the entire unit with Satin Black, dropped the tweeter in (positioning it so it was slightly tilted at the same angle as the windshield), and screwed them into the factory openings with the factory clips and screws. Yes, I ruined the factory speakers but I was never going to use them again anyway and the frame was perfect for mounting the tweeters. Here's some pic's of both the dash tweeters and the kick panel woofers.
    Original front speakers
    Name:  Front speaker.jpg
    New tweeter mounted in the middle of the factory speaker frame. I've since painted the silver trim ring in Satin Black.
    Name:  Front speaker II.jpg
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    11.49 @ 121.86
    307 rwhp/278 rwt
    12.38 @ 111.38
    Jun 2013
    San Diego, Ca.
    A possible option for tweeters is this, found in GM Suburbans and Tahoes.
    Kind of ruled out 'kicks' due to the tight mounting area, shoe hits, moisture, dirt, tracked in.
    Just as well, speakers can be changed out every few years as needed.
    Marine speakers could be an option. Usually white though. Good for white interiors?
    I have these JBL dash speakers and very pleased with them. Fit great. Clean clear up front sound fill above mid bass.
    Product detail mentions optimizing off-axis sound performance and OEM-Level Reliability Testing.
    Real good deal on now for these and others:
    http://www.harmanaudio.com/car-speak...eakers#start=1
    FEP Senior Member Quicksilver's Avatar
    May 2011
    Ontario, Canada
    Quote Originally Posted by Mentok View Post
    Mentok, yes my kick panels are the Q-form ones. A friend of mine had bought two sets for a 1990 Mustang and I got one of them from him.
    No modifications to the panels were required for a four-eyed car.
    They came without holes cut in them, so I just test fitted them, cut the correct size speaker holes, painted to match, put in the speakers and tweeters, connected the wires and put them in. You have to drill one hole for the screw to fasten into the sheetmetal. It was an easy swap of kick panels. I still have the original kick panels if I ever change my mind.
    I did use Blaupunkt Overdrive ODc650 ULTRA-SHALLOW MOUNT Overdrive Series 6-1/2" 2-way Component System that I had bought a couple of years before, but there is lots of room for conventional speakers as well.
    I also disconnected the dash speakers at the same time. With the kick panel speakers, the sound comes at you and not at the windshield.
    Rob
    May 2011
    Ontario, Canada
    gr79,
    It all comes down to what works for you. If you're pleased with your system that's great.
    I have had the kick panel speakers in the car for about 3,000 miles of driving now and I enjoy them. Having said that, my car is automatic and it is not daily driven. With mine, I started from the stock AM/FM cassette without premium sound and went to this. Considering my starting point, IMHO these really make a big difference over the stock audio system with dashboard speakers.
    This is the driver's side when it was apart.
    This shows the passenger side
    This picture shows the amount of foot room on the driver's side.
    Hope this helps.
    Rob
    Cool setup good pics.
    Agreed- each setup and person is different.
    We all have to figure out what we want. Sharing info and pics to help others.
    Way back had a 67 Mustang verti. 6x9's in the kick panels. A bit much but rocked.
    Next level up, that's where i will add some 5's or 6's.
    Mar 2010
    Portland, Maine
    Quote Originally Posted by Hissing Cobra View Post
    I planned on doing this tomorrow only with powerbass 2xl comps. Unfortunately ebay seller sent me the powerbass 3xl comps. Normally I wouldn't complain since the 3xls are $50 more, but they are 2.8" deep as opposed to 2.2". At least they sent me the right 6x9's so I can do the rear. Original owner cut the rear quarter and put pioneer 6x9's in it, but the surrounds are dust. Going to reuse the 80's pioneer grills though.
    I might just put them in my b3000 since that has plenty of depth. I could use the 5.25" comps in that for the capri as they are pretty shallow.
    May 2002
    Let us know how you make out! Just remember, if you're doing the kick panels speakers, you'll have to make a round spacer to go behind the kick panels to space them away from the metal of the unibody.
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    11.49 @ 121.86
    307 rwhp/278 rwt
    12.38 @ 111.38
    Mar 2014
    Omaha, NE
    Great thread! I am curious on the Q-Form Kick Panel setup. On Robs setup, he has an automatic which appears to be ample room in the footwell but my car being a manual, I wonder how close that setup would be to the clutch pedal?
    Brock
    Just noticed your post here Brock.... I would not try those with a manual. I would do dual cone 3.5" in dash and tweeters hidden in the vents.
