Results 1 to 13 of 13
    Apr 2008
    Waikoloa , Hawaii
    Default Exterior mirror trim - What is it and where can I get it?
    1986 t-top, coupe - What is this circled piece called, and more importantly, where can I get a set ?
    1986 CHP SSP Coupe
    Apr 2008
    Waikoloa , Hawaii
    Weekend crew?? Anyone?
    1986 CHP SSP Coupe
    Here is the driver side NOS.
    http://www.ebay.com/itm/NOS-1986-FOR...fc12d7&vxp=mtr
    Unfortunately I was not able to find a full set. Basically that was a trim piece that was installed to help improve the looks when the T-top conversion was performed. The full roof cars did not use it as they have the full window frame.
    Good Luck!
    Trey
    Apr 2008
    Waikoloa , Hawaii
    Any idea the 'technical' name of them Trey? I guess I'll call foxresto Monday and see what they say otherwise.
    1986 CHP SSP Coupe
    Unfortunately I don't know the technical name for that piece. I know I have seen it before, but being sick and on a rig right now, I don't quite have my normal brain power so I am at a loss! Sorry! I will see if I can find something for you.
    Trey
    FEP User
    Nov 2013
    Central New Jersey
    In the T-Top restoration (service) manual, i believe they refer to it as a weatherstrip retainer, which it does in fact do: it keeps the glass channel weatherstrip from pulling up, or the rubber itself getting mangled when closing the door. I am missing the drivers side on my t-top and the passenger side was broken and only had the trim part crudely glued on. my solution when i replaced the channel weatherstrip was to use weatherstrip adhesive, and some black silicone to help blend it in (on the top of the door frame). but then again, i also used modified aero mirrors, which cover more of the exposed door frame, and made it easier to conceal.
    Also, although it is considered a weatherstrip retainer, i have rarely seen it go by that name. Mirror trim, door trim, accent piece, or any combination of the above will usually net you some results
    I have a used passenger side one if anyone needs it.
    1983 5.0 GT convertible. Restored 2011 - 2014
    I know this is an older thread but I am searching for the same thing. The passenger on is E6ZZ-6620476-A. Does anyone know what the driver side part number is or where I can get a set?
    1986 T-Top GT
    Bringing back to life - almost done
    2R paint
    I know this is an older thread but I am searching for the same thing. The passenger one is E6ZZ-6620476-A. Does anyone know what the driver side part number is or where I can get a set?
    1986 T-Top GT
    2R paint
    Quote Originally Posted by submakr View Post
    Most likely the driver side part number will be the same except for the last number. Even is passenger and odd is driver in the old Ford part number system.
    My guess would be E6ZZ-6620475-A of course that assumes that both are E6 numbers too. Good Luck!
    I actually found a set of NOS trim pieces with weatherstripping on Ebay a few months ago just by chance. I have no idea what the part numbers are since they were unboxed, but it was cool to find them. I plan on using them on my 82 RS T-top.
    Would be good items for 3d printing.
    Jul 2010
    Houston (Clear Lake), Texas
    To expand your search, those came on the convertible cars also.
    HAD
    HAVE
