HEY Foxchassis how many LTD LX you show made in 84 and 85? Just got a Marti report done on mine and the numbers are a lot higher. It shows 3367 lx produced for the 1985 LTD and 8491 with that powertrain? Thanks
If I remember correctly, I have seen only one Marti report for the LTD, and it was for a Police Package. I have not seen any "verified" LX production numbers, only Internet lore.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I had one done recently follwing your steps of putting it in as a mustang and it all came up but the numbers were higher than i thought. Folk lore is beautiful thing. LOL
Internet lore pegged total production of the 1984-85 LTD LX at 3260. If your report is showing more than that just for the 1985 model year alone, you can consider than 3260 number to be officially blown out of the water.
The powertrain number on your report matches what I have seen before. That just means there were that many P39 (LTD 4-door sedan) w/ a 5.0L engine and AOD trans made in 1985.
I know of only two ways to get a 5.0L/AOD in an LTD in 1984 and 1985: the LX option or a 'fleet' (Police Package, taxi, etc.) order.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
I agree , I was wondering if you could have order a LX with a 6? I know for a fact that one off stuff use to happen back in those days. The only saving grace is that report also shows that this is one 948 with this paint/trim codes also one of 4 ordered from this DSO. Bulit in 4/85 and sold on 7/85.
Just got an email from Ken Marti saying all LX had 5.0 so the 3260 number is history!
sorry Kevin marti
Thanks for the follow up with Marti on engine choices in the LX. So it is confirmed....LX could only come with 5.0L engine.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Can you post pics of any factory or dealer documentation, sticker, tags, etc. that you have?...door tag, buck tag, axle tag, build sheet, window sticker, invoice, etc. Thanks.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Marti suggest having a owner of a 84 ltd lx do a report and we should get the true production numbers. I really like to see what happens with the new 5 speed lx that just popped up too.
Per 1985 Ford LTD dealer brochure page 21:
LTD Sedan
LTD Brougham
LTD LX
LTD Wagon
2.3/Selectshift = std Sedan, Brougham; n/a LX, wagon
3.8/Selectshift = opt Sedan, Brougham; n/a LX; std wagon
5.0 HO/AOD = n/a Sedan, Brougham, wagon; std LX;
Then there was the Canada only Marquis LTS..
Bob Bondurant’s Racing School red 1984 LTD
There were 3260 LX's built. All with Automatics. All other mid size V8 LTD's were police package units, also all automatics. And they sold a butt load of them. One of the most popular cop cars (with the cops) ever. Significantly cheaper than the Crown Vic's of the period, which by the way were available with carburated 400 ci V8 until 92 model year, depending on what part of the country you were located, (sorry Cali, not available there).
Also the LX nomenclature referred to above was a comfort trim level that was available. NOT the LX performance model.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
There were never any 400Ms. After 78 the only thing you could get a 400 in was a truck or van.
Dave
1983 Capri RS Turbo
1981 Black Magic 400 c6
93 F-250 351 5sp 4x4
Marti does know what was produced it seems like it could be correct. Low production first year and mass build out for a model that will not be made in the future. Liquid when does it show yours was produced?
Low production in the first year (1984) is because the 5.0L wasn't available until well after the model year started. (Lowest P39M VIN for 1984 is EG141755.) Production was higher in 1985 because it was available the whole model year. (Lowest P39M VIN for 1985 is FG100004.)
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
According to Marti Auto Works...
1984 LTD LX = 1920 produced
1985 LTD LX = 3367 produced (1447 more than 1984)
Total 1984-85 LTD LX = 5287
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
