That's quite all right, yeah I found out today that they don't fit. I'll order the correct ones. I appreciate your help.
'79 Fairmont Futura
'79 Mercury Zephyr wagon
'83 LTD Wagon - future Mustang "Sport" Wagon
'84 Mercury Capri RS - 5.0 5spd
Owner of Victory Engines and Machining, LLC
g2G
Here's my own before and after
Once I got it apart, it still wasn't that clear that that was the problem (I didn't have my metal one yet), but if you compare them side by side, it becomes obvious. I'm really happy to have that solved. I've started working on my power window conversion!
Since I started doing this myself, I've heard from a few other guys with early cars they have floppy windows too. Design FAIL with that plastic bracket, for sure.
The driver's window on my LTD is pretty wobbly. This thread was helpful. I'm guessing I already have the metal bracket but I bet the square bushing is toast. I really need to pull my driver's door off and fix several things.
Brad you don't happen to have a part number or the technical name for the metal bracket do you? I have the same issue with my passenger door window.
The part number is E3BZ-5423288-A
As far as I know, they can't be had new. All the Ford Parts site shows is window motors. I've seen them called window brackets and glass brackets. And hey, look what I found
I put the part # into google and had a bunch of stuff come up I'll have to check out. I wonder how a guy could extrapolate the driver's side? Parts gurus?
Here's another passenger side one. Doesn't help me though!
http://www.ebay.com/itm/NOS-1981-198...item5b025bfef1
SSSSSIIIIIGGGGGHHHHHH The things you find after you don't need them anymore. I even posted in it!
http://vb.foureyedpride.com/showthre...fairmont-wagon
At least I now have the driver's side part number! it's E3BZ-5423289-A
Well guys, I did some more looking around, and these things ARE out there. First I tried eBay, no luck for a driver's side one. Then I tried putting the part number into Google. Lots of listings come up that are various Ford Parts pages, dealers and such, that pretty much tell you "yes, that is a Ford part, but no, you cannot buy one". There's a useful page though called rearcounter.com that seems to be a kind of broker for other companies that sell NOS parts. One is Green Sales out of Cincinnati.
I found one at NOS Parts LTD. I had an inquiry in to Green Sales, but they weren't getting back to me, so I got antsy. I decided to try the Granada part number, which is the same part. Not that I ever cared whether they were NOS or not, but that seems to be what's readily available, and for reasonable money too! They both cost me about $30. Here's a recap of the part numbers.
E1DZ-5423288-A Granada Right Side
E3BZ-5423288-A LTD Right Side
E1DZ-5423289-A Granada Left Side
E3BZ-5423289-A LTD Left Side
These are the SAME PART, LTD or Granada, just different part number for different models.
Thanks! Definitely check out that rearcounter.com for brackets for your car!
Alright, here's the proof the Granada piece is the same. I ordered this sight unseen using E1DZ-5423289-A, and here's what I got in the mail today
I imagine they started using this metal bracket across the board in '81 because the plastic ones wouldn't stand up to power window duty and they expected most Granada/Cougars to be equipped with power windows.
Excellent! Time to order a pair for my Boxtop, tired of rolling down rattly windows.
Awesome read. Just getting ready to replace my passenger glass and was wondering what might help the rattle.
What an awesome read, quite a bit of work ,at the comp, and on the car to come to this end. I'll be trying to find a couple of the metal ones my self.
Thanks for all the input.
jim
Will Rogers" common sense is not as common as you think"
FYI, guys. For some stupid reason i decided to pop out the bushings that came with the glass bracket on the driver's door and put the convertible ones i got from LMR in. DON'T DO THAT. If your glass bracket comes with bushings, leave them in. My driver's door glass is as loose as ever.
As far as i can tell, the only solution would be to either buy another glass bracket and use the bushings that come with that one, or rig up a bracket with felt on it that holds the window solid when it's down, kind of like convertible/t-tops have. Another thing i thought of is maybe try and make window tracks, but i imagine they would need a very specific curvature, and since these never had tracks all the way up to the '86 LTD, there probably isn't really a way to do that.
Long story short, the convertible bushings from LMR did not work out for me.
