Ok I usually work through most issues on my own but i am gonna throw this one out there and see what happens. I usually consider myself pretty good with foxbodies but this is a little puzzling.
I have a 86 GT. When I pulled the motor a few years ago to do an extreme engine and engine bay makeover I made a few mods. I would like to point out that after buying the car, I went right into pulling the motor so I cannot say if the problem was there before hand.
I pulled the motor to clean, paint, re-gasket, etc... while apart I installed a Crane model 2020 cam (designed for speed density cars) and a explorer upper and lower. I deleted ALL emissions equipment during this time including the EGR. I am running a stock 86 Mustang throttle body on the explorer intake. All vacuum lines were replaced but also allot deleted if it was emissions related. It has stock heads, ignition, offroad H pipe, etc. I did a Mass Air conversion before startup as well. After startup, the car would start great but after idling for a short time it would go into this really bad sorta limp mode where it was loading up, running rich and just over all idling like crap. Well after fighting it to no reward i decided to go to speed density. Well it got better but it didn't fix it. I had to end up running the car with the butterfly on the throttle body cranked way open with TPS voltage reset to about 1.0 volt. It seemed to still have the same proper start to then begin to act up after idling for a short time. The only some what fix seems to be having the butterfly way open on startup. IAC has been replaced, TPS is good and MAP sensor has been checked. The one thing I never did during all of this was replace the O2 sensors. I desided to swap the O2's for a new set recently but it acted the same ( I did NOT pull the battery cable and reset the EEC). I checked at the O2 plug, I have a good ground and the 12 volt positive with key on. Haven't checked EEC voltage at the O2's yet. I am wondering if I need to make and install a EGR Fake plug? I can't see why no EGR would be doing this but who knows. I am sure it has a code or two from stuff that was deleted. Maybe I need to see how it acts with new O2's after pulling the battery cable for awhile to rest the EEC. Anyone got any ideas???
