Results 1 to 15 of 15
    Default EXH light on non feedback carb, CA spec Bcode I6
    For a while, this has bugged me.
    Since a B and X code O2 sensor I6 3.3 Liter isn't a feedback carburettor, why is there a red EXH dash light?
    Its not MCU, EEC II or III like the 2.3's and 4.2's were for CA that year.
    What purpose does the heated O2 sensor and its white /black stripe, yellow/ black stripe heat insulated wires below have
    asside from controlling the air pump TAB system.
    Is it used as an altiude compensator?
    The only other adjustment, and a non feedback one, is the orange null knob for idle speed solenoid setting beside the valve cover by the throttle cable.
    The two wire heated O2 sensor sits under the primary thermal cat, and is it only used for AIR operation, or is it used as an altiude compensating device.
    What gives with the non feedback carb I6, with a feedback AIR, dual catalyser exhaust system?
    That's a new one for me? I've never seen anything like it before.
    Cheers!
    Mike (TopGear85)
    Have:
    Had:
    79PC-San Jose #2890
    90GT-Oxford Wht,5spd
    Hugh?
    Terrymwalshes is like mine, CA spec, 1981, ex SanJose CA plant. But it doesn't have the red EXH light?
    Dang, now I'll have to PM Terry, and look at all my old B and X code photo's.
    Sent this to TMW
    Thanks in advance if you can help, since most of the old log head stuff is removed, you might be able to help a little.
    I guess I assumed too much.
    Terry, do you have an EXH light on the left side of the dash on your WBM. Its found on my non feedback carb, CA spec B code I6?
    What about a two wire O2 sensor. According to your Emissions equipment tag you should at least have a white covered twin wire O2 sensor and an idle adjustment null knob.
    I guess mine might be a little different.
    See http://vb.foureyedpride.com/showthre...35#post1711535
    Kindest wishes, Dean from Dunedin NZ
    Well, the twin wire O2 fitted on to the primary cat B aNd X codes
    The idl adjustment is commonto all 81-83 engines.
    It's just the O2 sensor and EXH lightI'm confused about...
    FEP Member Foxy Capri's Avatar
    Sep 2006
    Melbourne, Australia
    Hi Dean. I don't have an EXH light but I think mine had the O2 sensor, I'll check in the morning in my box of left over bits & pieces! I attach my Emission Control label from under the bonnet, that's hood, if that helps at all.
    aka Terry M Walsh
    Downunder in Melbourne, Australia
    1981 Mercury Capri, 'White' Black Magic, 200-2V/C4
    1983 Ford Capri, 2.8i, 5-spd
    Oh, thankyou Terry. Wow!
    From your birthday back in 11-09-2012!
    http://vb.foureyedpride.com/showthre...Window-Sticker
    What emissions lable do you have, it lookes the same as mine
    Zackly the same as yours!
    Snap! E1BE 9C485-CA, Engine catagory AM, DCK, same IJ 204 AA engine decal, everything.
    The O2 sensor isn't a vac decel item.
    And I see that not everyone got the O2 sensor.
    Here's a Wedgewodd Blue Mercury Capri 3.3 1981 engine, it doesn't have it. Its emissions package is totalyy different, with its AIR tube system different. I seam to remeber it was a Collorado car, found in the snow outside a barn by a Ford Six member baack in 2003 or so. In 1981, there were a raft of changes between manual, auto, and 49 states cars.
    Despite the engine being an in line, the exhaust manifold curls down under a cast in intake, so its hard to see everything, with the AIR system and catalytic converter cover having to be removed before you can see anything.
    I took the O2 sensor out June 2011, but didn't get any photos saved, the SD card was wiped. I do have other photos though, including the Cat part number
    E1 BE -5E211
    5G D8--0 256
    Sep 2006
    G'day Dean, you'll have to excuse my ignorance, but I have no bloody idea what all that emissions stuff is or what it does. I'm an old school mechanic, plugs, points and an oil change, that's for me!
    Anyway, attached are 2 pics of a lot of the rejected stuff off my I6 200, along with a close up of the item I thought that you were talking about. Hope all this helps, and I definitely don't have the EXH light. Cheers, Terry
Size:  88.7 KB Name:  O2Sensor.jpg
    aka Terry M Walsh
    Aha, your stuff is the carby control idle and air cleaner thermatic and air pump stuff.
    Just like mine. I'll bet you were happy to see that stuff go! That is about 30%of the emissions gear right there, Terry
    I found my lost six pack of catalyst, heat shield and O2 sensor pictures! The cat is a big old thing...
    "IMG_6861"
    "IMG_7222"
    "IMG_7223"
    "IMG_7224"
    "IMG_7227"
    "IMG_7228"
    The O2 sensor has two wire, white /black stripe, yellow/ black stripe link-up, with 2-3/8" probe into the catalyst distance, its mounts at about 3-1/2", and about 4 -3/4" long tip to outer heat wrap. Cant remember the thread, may be a spark plug type.
    What I see in those photos is a thermocouple exhaust temperature sensor, very likely aftermarket.
    Not sure if that would have been added to satisfy some import requirement, or just because some
    previous owner was concerned about exhaust temperatures, but that probe, and the "EXH" red light
    on the dash, do not look at all factory to me.
    Cheers,
    Jeff Cook
    Thanks everyone, JACook, terrymwalsh, Mike (TopGear85).
    I guess its a later added tell tale.
    I can hook it up to my data logger, I just thought it was factory, I thought it was period Fox.
    Shows you how little I know.
    Jul 2004
    Montebello, CA
    O2 sensors are only used with fuel injection OBD1/OBD2 1995 was the first time there were needed so before that they were not used
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Jul 2004
    Montebello, CA
    that light might be part of some kind of tow package
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Jul 2004
    Montebello, CA
    "IMG_6861"
    "IMG_7222"
    "IMG_7223"
    "IMG_7224"
    "IMG_7227"
    "IMG_7228"
    picture 27 and 28 is not an O2 sensor, its a thermo switch to protect the exhaust. those wires go to that light, possible tow package was installed on the car
    Past 4 eyes-
    U.S. NAVY 1980-2009
    I thought this was a tow pack....http://www.bestracingtips.com/fun-st...irmont-futura/
    Tell me more if you know. It's hard to imagine 91 hp taking out a football cat, but I've heard all sorts of folklre about the ceramic grid over heating and going on fire and suchlike, never believed it though.
