I was looking to replace my old original coil springs and found that Summit had Moog 8600 stock replacement springs. After the install I was stunned by the ride height ??? I wasn't looking for the old school Gasser look, or clearance for ghetto rims.. I looked to see if there was a jack stand holding the car up so high... I thought I was getting a spring the would leave the car at the stock ride height.. Please don't reply and say they will settle because there NOT going to drop 6 inch's.. I'm just currious has anyone had this happen with the Moog? I'm very disappointed that summit would offer this as a stock ride height spring.. yes there installed correct and sitting perfect... I will be cutting a coil or two out on monday...
