I've been tweaking the idle on my 84 5.0 CFI for a few weeks and I cant seem to get it to run right 100% of the time.
Its very strange. After setting the adjustment on the dashpot to run at 550 RPM it seems fine. The car chokes good now, drops to low idle when its supposed to, but then I go on the parkway to drive to work where I'm running around 60-65 MPH for about 20 miles.
As soon as I get off the parkway my curb idle runs between 750-900 and my parked idle at about 1200 rpm.
No idea why it changes after opening up on the parkway. Then when I leave work, similar thing. I leave work idling at 550 rpm, I get off the parkway about 6 miles from home running at 750-900 BUT shortly before I get home, it drops back to the correct 550 in drive and 1000 in park.
Somehow I feel my dashpot is getting too much vacuum and taking too long to adjust itself. If I ignore it, it eventually drops to the correct rpm. But I have to drive along time for that to happen. If I just drive locally around the neighborhood, the rpms stay correct at 550. To continue to play with the screw on the dashpot is a waste of time. Although I may remove it and reseat as it seems its at the end of its adjustment slot on the mounting bracket.
When it runs at the correct RPM it runs nice, but I'm still getting poor mileage. Its a brand new Motorcraft dashpot, brand new vacuum lines, brand new diaphragm in the choke pull off. Definitely no vacuum leaks in the dashpot system.
Any suggestions to get the dashpot to behave?
