Ok I mentioned this in another one of my posts. The car is a 80 Futura 3.3 auto/column. Soon to be 363 stroker/c4/column shift. I am going to use 90 GT spindles. I was going to use a 90 k member but you guys educated on that. So I was going to use a 83 k member to keep the correct width. Then I came across the UPR tubular k member kit, coil over with 1 inch shorter a arms. I like the idea of this. It will help wheel clearance issues, as well of all of the benefits to using a tubular k member. However I am concerned about no sway bar. The car will mostly be a weekend warrior. UPR sells these arms with and without the sway bar mount. I'm just not sure if the 90 GT sway bar will fit if the a arms are 1 inch shorter? Also will these tubular members bolt in the exact spot? I had trouble with my torque box kit, as the floor pan is slightly different in the fairmont. Does the front clip of the car have the same mounting holes as the mustang? Any other thoughts on this set up? Has anyone tried this? Sorry for all the questions. I just dont want to buy parts that wont fit. Thanks
