Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
  1. #51
    FEP Senior Member 4eyes's Avatar
    Nov 2014
    Union, KY
    Default Build Sheets Located
    Struck gold! As I started removing the interior, I found the build sheet under driver's seat carpet. Unfortunately, it stuck to the floor pan and disintegrated during removal... Bummer!
    But have no fear, when removing the passenger side rear panel, I not only found another copy of my build sheet but a copy of another car's taped behind it! See pics below...
    FoxChassis, I've attached a PDF of the build sheet, can you decode it for me? In particular, can you help me understand the correct spring codes? My original door tag is illegible and Marti had to guess on those.
    Also, would you like me to upload a PDF of the other build sheet?
    '84 Tu Tone Coupe 5.0/T-5 Dark Academy Blue/Light Academy Blue Glow
    '86 Mercury ASC McLaren Coupe 049 - November '16 ROTM
  2. #52
    Yes, I would like to see the other build sheet.
    The door tag springs codes for EF141204 were KKHH. Build sheet decoding is forthcoming...
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
  3. #53
    That's awesome! (The build sheet for the other car.) Look at how far apart their C.U.N.s are!
    It would be cool to do a carfax on the other car, to see if it's still out there.
  4. #54
    Nov 2014
    Union, KY
    Ask and you shall receive, I did an AutoCheck on the car and posted it with build sheet on a new thread:
    http://vb.foureyedpride.com/showthre...06#post1735206.
    It would be awesome if someone could find this car. Last registered in Missouri 17 years ago.
  5. #55
    I had to do this in a hurry, so if there are any mistakes or things left out, I will have to do it later.
    I will do the other build sheet later.
    Build Sheet
    Line X
    831128 = November 28, 1983
    1636 = 4:36 PM
    Line A
    Rotations Number - 4042 = trim and chassis rotations #4042
    Line - Z = Mustang model line
    VIN - P26EF141204 = [decoded above]
    Body Type - 66B = Mustang 2-dr coupe/convertible
    Body, Tops, Color - [blank] = no convertible top
    Body, Tops, Roof - [blank] = no sunroof, no T-roof
    Ext, Paint, Body - 5C = Dark Academy Blue Metallic exterior paint color
    Ext, Paint, Accent - 35 = Light Academy Blue Glow lower accent paint (special tu-tone paint)
    Ext, Tutone - C = special tu-tone
    Int, Trim - AB = vinyl seating, high-back front buckets (A), Academy Blue interior trim color (B)
    Int, Deviation - [blank] = no interior trim deviation
    Type of Order - Z = Retiree Purchase Plan
    Region & District - 76 = Denver district sales office
    Special Order - [blank] = not a special order
    Line B
    Engine - M = H.O. 5.0L V8 engine
    Trans - 2 = manual Borg Warner transmission (5-speed T-5)
    Air Cond - M = manual air conditioner
    Engine, Tag Number - EK333AB = 1984 model year (E), 49-state Thermactor emissions (K), 302 engine (333), calibration level A, revision level B
    Transmission, Part Number - E4ZR DA = manual transmission (R), originally engineered for 1984 (E4) Mustang (Z), revision level DA
    Seats, Type - H = high-back bucket seating
    Belts, Color - B = Academy Blue seat belts
    Line D
    Electrical, Wipers - W = interval windshield wipers
    Electrical, Defroster - [blank] = no electric rear defrost
    Electrical, Audio, Radio - S = AM/FM stereo radio
    Electrical, Audio, Spkrs - 4 = four speakers without premium sound system
    Electrical, Lights, Light Group - [blank] = no light group
    Power Aids, Deklid Release - [blank] = no remote decklid release
    Power Aids, Locks - [blank] = no power locks
    Power Aids, Windows - [blank] = no power side windows
    Glass, Tint - T = tinted glass
    Mouldings, Bodyside, Color - B = bodyside molding with Blue inset stripes
    Air Dam - [blank] = L/LX front bumper cover
    Road Abrasion - [blank] = no road abrasion coating
    Console - C = console
    Line E
    Battery - DA = regular duty battery (45 amp-hr)
    Driveline, Rear Axle, Tag Number - 271D = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    Brakes, Type - P = power brakes
    Suspension, Springs, Front, Left/Right - KNO = door tag code K
    Suspension, Springs, Rear, Left/Right - NOL = door tag code H
    Pkgs, Hndlng - X = Handling Suspension package
    Line F
    Wheel Area, Wheel Covers - F = unknown
    Wheel Area, Wheels 1/2 - RY = unknown
    Tires, Size - 205 70R = P205/70xR14 tires
    Tires, Color - [blank] = black sidewall
    Speed Control - [blank] = no cruise control
    Front End, Cover/Pad - D = vinyl wrapped GT steering wheel with Ford oval
    Front End, Steering Wheel, Type Wheel - 3 = steering wheel without cruise
    Front End, Steering Wheel, Type of Col - [blank] = no tilt steering wheel
    Hood Scoop - [blank] = no hood scoop
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    Accent Stripe, Type/Color - F1 = Blue paint stripes
    VIN - 1FABM0 = [decoded above]
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
  6. #56
    Nov 2014
    Union, KY
    Thank you FC!
    I peeled the tape off exposing the TuTone code, see pic below.
    Thanks again!!!
  7. #57
    Corrections made above.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
  8. #58
    Great read ... with my body getting back to a new "normal", and our family's commitment to finishing Cameron's three coupes, the Tu-Tone threads are certainly motivating.
    I wish to thank you dedicated contributors for the positive affect you are having on me to now pull some interior in search of much needed data about Cam's '84 5C/1E Coupe. It has been a long year dealing with my health related issue and certainly a journey getting into my son's cars. Maybe one day, I will have the privilege of meeting our Tu-Toner group to cop a nice manly hand shake and a cool beverage.
    Chris, the Marti report, where do I find pricing?
    Featured 4 Eye: 84 Tu-Tone 5C/1E - Dedicated project resto-mod for my son Cameron Lee. :tu
    4 Eye past:83 GT - project, traded for a boat load of goodies to finish other cars.
    86 Coupe - Gave to a friends son - being restored. 86 GT - Gave to another friends son ... finished.
    Our Current Fords: 66 F100/FE, 84 Coupe/Tu-Tone(5C-1E), 87 Coupe/408 drag car, 89 GT/347, 90 Coupe/347/Supercharger, 94 Ranger, 98 Explorer/5.0, 04 Cobra SVT, and ...
    Ford Fun-a-tic / Lithia, Florida
  9. #59
    Marti Reports
    Follow that link, fill in the vehicle information, and click on the red arrow to the right. The next page will bring up the report available for your vehicle, and the current prices for each. The "Upgrade" option is is you have already purchased a report and do not want to pay the full price for an upgraded report.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
  10. #60
    Marti Reports
    Thanks Mick ... silly me.
  11. #61
    Nov 2014
    Union, KY
    Quote Originally Posted by StangItMan View Post
    Wow Greg, that's very kind of you to say. My goal is to help others learn and hopefully get excited about these cars. IMO, fox body Mustangs played a huge part in the horsepower renaissance and deserve to be documented. Plus, if demand grows enough, we'll see more high quality resto parts being produced and the cost to restore will become more affordable.
    I promise Greg, once the restoration is complete, I'll be down your way for that cold beverage (or few) and a firm hand shake!
  12. #62
    Mar 2013
    DENVER CO, the 303
    Amazing!!!
