Ok guys I want to see how fast you have been down the quarter mile track with your stock block . I've been as fast as 10.52 at 131mph with my turbo set up on my 306 . Looking to go low 10s or high 9s. Next year. Lol lol .
1993 Mustang GT ,393w TKO600 .
2015 Ford F150 FX4 3.5L Ecoboost.
2:14... oh wait, you did not say around the track...
From my phone
1986 Ford Mustang GT-
Not much stock stuff left
347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
Suspension, custom k- member, TQ arm/pan hard rod... Much more
Restored and ready to race, made to go fast while cornering
1981 Mustang GT-
Old SCCA A-Sedan National Champ car
In the middle of rebuild
1986 LX Sedan-
Plans to be determined...
"Every day I learn how much I don't know"
I know, was just kidding.
From my phone
1981 Mustang GT-
1986 LX Sedan-
This guy is running deep into the 9s with a stock 351. Stock bottom end, and heads. Boost and suspension. AND it's a four eye.
http://www.theturboforums.com/thread...11-13-9-73-140
Jess
Previously owned;
89 Lx, 310 cubic inches, full weight, c4 rollorized, 4.10 's, edelbrock heads, comp can, 175hp shot.
1/8 mile went a 6.89 @ 100mph.
Car was a daily driver.
86 GT convertible, 100% stock: 16:02 @ 96mph.
This was the day after I bought the car, before fixing broken vac lines, tune up, etc.
Went to the strip with a friend of mine who has a supercharged 96 Cobra. LOTS of upgrades, but stock block. He runs in the 10.1's (looking to break into the 9's)
12.98
stock 00 explorer 5.0 with 120k,comp XE274HR cam Edelbrock preformer air,fms shorty headers,x pipe and 40 series,under drive pullies, fresh t-5,king cobra 10.5 clutch,Hurst short throw shifter,fms alumin drive shaft, bbk frame conectors, 8.8 4;10 , MM camber caster plates, MM XD ADJ lower control arms
The one I'm most proud of is a 13.01 average for the day
302, C4, iron heads, flat tappet, on real street tires
Took home a Tremec True Street trophy
Completely stock short block, all internals stock. Holley aluminum heads, blow thru carb, C4 with an On3 70mm. 3400lb race weight wagon with me in it. 10.15 at 127.15 on a 1000' shutdown pass. Hit the high side rev chip and got out of it. If I recall right it went a high 6.teen in the 1/8 at 110ish with a 1.4 sixty foot, been a few years.
1979 Fairmont wagon 414ci (stock block), 88mm T6, TH400, 9" rear 8.92 at 152.
1980 Boxtop 306 w/70mm, 10.05 at 142.66 (traction limited) Dart blocked 331ci, S480
1981 Fairmont 4-door project. 441rwhp on 12.5psi. (SOLD)
My fastest was 14.99.. will be working on suspension this winter hope to dip into the 13's stock block basic gt40 setup
I've got a stock factory Ford block that's been notched for clearance on the bottom of the cylinder bores in order to make way for the Eagle 347 stroker kit. It's naturally aspirated and has got me a best time of 11.49 @ 121.86 mph.
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
420 rwhp/380 rwt (New Motor)
11.49 @ 121.86
306/T-5/4.30's (Old Motor)
307 rwhp/278 rwt
12.38 @ 111.38
My 3100 lb 85 Mustang LX HB has gone a best of 10.28@128 mph, 1.37 60 foot, with a stock 5.0 block. no power adders, and a 4 speed Jerico, launching at 6200-6400 RPM, shifting at 6800, hits 7200 thru the finish line.It is a production hyd. roller block, but I have a solid flat tappet cam, a 3.25" crank (331 cubes). A buddy has gone as quick as 9.8s @ 135 MPH, also with a stock block, also "all motor", with a Jerico, he has a standard bore 5.0 block, with a fill of Hard Block, but his car only weighs 2700 lbs including driver. He has a zero balance crank, and has been as high as 8400 RPM. However, upon taking the engine apart to freshen it, they discovered a pretty big crack running from the #2 main bearing bore, to the cylinder bore, so hes scrapping the stock block, and has bought a big bore Dart SHP block, and will be building a 358 cube 302 for next season. With the extra cubes, and big jump in compression, and abigger solid roller, hes hoping for 9.5s in the spring, again, all motor.
Back in the late 80s early 90s I went mid 10s with nitrous on a stock shortblock. Never had a problem with it and ended up adding another plate to it (two stacked) and still never hurt it.Never used both plates at the track but it was fast on the street.
Around the same time my friend went mid 9s @ mid 130s N/A with a stock 302 block. His was an early non roller block but it had all good light weight stuff in it. He went these numbers with J302 heads, non roller solid cam and an offenhouser portosonic intake. . He was probably one of the best SBF guys in the country.
A bunch of 85gt's
No quarter mile times; but 1/8 was 6.96 @ 101.9 Stock 152K shortblock. Single nozzle. T5
Somewhere down in Texas...
Not a 4 eye, but my 87 GT went 10.85 on a 1.54 60' and a race weight of 3,350. Stock 1990 302 untouched bottom end. Hoping to nip that time down this year and improve my MPH a bit through more aggressive driving.
1987 Mustang GT
S trim. 10.85 at 128. stock short block and stock T5.
2002 Mustang GT convertible.
auto with 4.10's and tune.
2008 Viper SRT10 Coupe.
11.33 at 127 bone stock everything.
That's getting it done! Nothing like that feeling when you feel that T5 slide into 3rd gear and you're still moving without any clunking or audible damage coming from under the console.
That 10 second territory can be very stressful with a stock shortblock ( I don't care if it's on spray, boost or NA); throw a T5 in the mix for good measure and surviving a Friday night T-n-T can be a very draining experience. Especially when home is an hour or more drive and there's not a tow vehicle involved.
OP-
How much boost your running and what heads and cam do you have? That's a great ET and MPH. I love the car too.
I was certain my combo should have cracked 130 but the DA that day wasn't my friend, nor was my granny shifting that preserved the trans.
1987 Mustang GT
Pete Slaney
1979 Mustang Cobra
347/T-5/4.30's
11.49 @ 121.86
307 rwhp/278 rwt
12.38 @ 111.38
1987 Mustang GT
