Is the fc 2 fi tank a direct replacement for the stock 79 Fairmont boxtop tank? are the filler holes the same size and location? Also is the airtex E2146S is the correct pump and sender for this tank? I am swapping in an 89 5.0 ho and want it to look as stock as possible.
