I've been looking for one of these for the last couple of years. I've never been able to find any factory documentation for this intake, and have only found a few anecdotal comments about them on the web. Occasionally I search for these on Google and last week I found this one on some obscure forum. I found that the part was also posted on Craigslist so I contacted the seller, made the deal, and it was delivered to my house today. Below is a photo of the 8311 next to the original intake from my car (I installed an Edelbrock Performer 302 earlier this year).
The reason that I wanted to find an 8311 is because other than the Performer 302, it's the only aftermarket intake that I know of that includes the EGR port on the carb flange. I intend to retain the EGR system, along with all other emissions controls. I want to eventually upgrade to a roller short block and aluminum heads, but believe that the Performer 302 intake will be a bottleneck.
For comparison, I took measurements of the stock intake and the 8311 as best I could. The dimensions for the Performer 302 are from Edelbrock's website. I don't recall the Performer 302 looking any taller than the stock intake, but maybe it is. It's clear from the photo above that the 8311 could easily be about 3/4" taller than the stock intake.
Front H Rear H Port W Port H 83-85 Stock 3.0 4.25 0.8 1.56 Edelbrock Performer 302 (3721) 3.4 4.75 1.1 1.8 Weiand 8311 3.75 5.13 1.06 1.9
One thing I noted is that there's not a lot of difference in port dimensions for aftermarket intakes. See the thread below, which provides dimensions of other intakes.
http://vb.foureyedpride.com/showthre...d-Dual-Snorkel
Since I intend to eventually install the 8311 with the factory EGR spacer plate, I may have hood clearance problems. I'd rather not install a scoop for clearance. The Performer 302 fits fine now, so if the dimensions above are correct, I only need to clear about another 3/8" to make the 8311 fit. I've thought about milling the 8311 carb flange down about 3/16", maybe milling the EGR plate a little, and taking out the hood insulation. I've read different things about convertible engine mounts, but am starting to believe that these won't offer any more clearance over the original worn mounts that are in there now.
