Been working on this project for a while and the actual switch panel has been done for a bit but finally got the rest of the interior buttoned up. I yanked some pillar gauge wires (by mistake) a while back so finally got them fixed...also, since I removed the info center I had to relocate the low fuel light. Finally found some small LED's I liked that ended up working out nicely. The other LED is my alarm light...not necessary at this point since it's not a DD but I wanted to keep it. You can see where I mounted it to the left of the radar detector. Stealthy and out of the way but visible to me.
I was able to find the SVO switches on ebay cheap - most of them (ended up getting 4 total) didn't even work and the harness was hacked so it worked out nicely. I re-built the switches (seen HERE in my write-up) and was able to use some of the old connectors.
I also added some switches inside the ashtray. When I first got the car (20 years ago - ha) I had my Bazooka tube switch in there...but wanted to add some others and clean it up so that became part of this project too.
Ok on to the pics...
This is the final product...you can see the new LED's just to the left of the radar detector. As mentioned just out of the way enough to not screw up the interior but perfectly visible by me.
Closer...
Here are the ashtray switches...
This is what I used to have in there...(also my line-loc switch...super hard to reach at the track...I've relocated that under the shift boot. perfectly accessible and invisible! lol. I also noticed that the nitrous outlet now sells a ashtray switch panel similar to mine...lol.
AND some car shots...freshly washed...
And to complete the thread some vids of me and Dad cruising a few weeks ago!
Me and Dad "cruising"
Quick holeshot...
Nice to be back and able to spend time with the car! haha.
