Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Quote Originally Posted by larry84gt View Post
    i like the way those vdo gauges looks... anyone use the Digital Dakota gauge cluster? its looks nice but pricey....
    If you price out a complete set of gauges for the stock cluster, the price is cheaper than the Dakota Digital units, but not by a huge amount. When you consider the DD unit is a plug and play, it's not a bad price overall. That is if you like the styling.
    Trey
  2. #27
    Aug 2004
    California
    I just purchased 7 AutoMeter gauges for my 86. Trey is correct - could have done it much cheaper. But in my case the 7 were more expensive than the DDs if you also consider the GPS speedo unit. Moreover, it has to be assembled in the stock cluster. I did the "ES" series which also uses a black face and bezel; through the dial led lighting in red.
  3. #28
    Jan 2003
    lansing, mi
    thanks for the kind words guys. this little project has been collecting dust for awhile now. i bought a pickup truck that i was torturing myself working on in the freezing cold when i was in the middle of this. now that the weather is starting to break, the capri stuff is top priority... and i have the top end off right now to install some thinner head gaskets. i'll update this with progress pics hopefully in the near future.
    cale
  4. #29
    Oct 2011
    Nampa ID 83686
    Looking forward to see how project progresses, Cale.
    Craig "IDMooseMan" Peters
    Buyer/Seller Experience Link
    Build Thread
  5. #30
    Jan 2003
    lansing, mi
    FINALLY got around to wiring this:
    It's been over 2 years since I really did anything with this. See all the wires? I started wiring this one way, didn't like it and rage quit until now. I'm going to do some zip tying when I get down to putting it in the car. Not sure if I'm gonna have to take a step drill to my dash hull the clear some of the bulb sockets but I'll find out soon enough.
    I even bought an sn95 vss because it had been so long that I had forgotten I had purchased a VDO hall effect vss. We've been spoiled with warm weather this winter (knock on wood) so I'm waiting for a warmer day to cut my original cluster plugs and solder and heat shrink in the new deal.
    Cale
  6. #31
    FEP Power Member magnum517's Avatar
    Jul 2009
    Telford, Pa
    Cale, that's cool that your back on it. Look forward to seeing it progress as it should look great when done!
    --86 GT vert.306,Powerdyne blown 7 psi, E303, ported E7s,MAF conv, BBK shorties n OR H, 3" Mac Pro Dumps, WC T5, 5 lug'd, 17" Bullitts, 3" cowlhood, SN95 Gt front brakes, 4.11s.
    --Bill
  7. #32
    Looks good!
  8. #33
    Jan 2003
    lansing, mi
    Thanks guys! I just realized there will no longer be a high beam indicator... I guess I'll just have to be careful about that.
    Cale
  9. #34
    Great thread, joining so I can use some of these ideas.
  10. #35
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Look at post # 3. That is my gauge cluster with the High Beam Indicator in Blue at the Left.
  11. #36
    FEP Super Member 86fiveoh's Avatar
    Jul 2008
    West chester PA
    What did you do for the high beam indicator? And turn signals? Is it easy to wire in?
    Boss block 302, vortech blower, 473whp@12 psi
  12. #37
    Jan 2003
    lansing, mi
    I got this project completed shortly after my last post, but never had any good pictures. The pictures I had were showing a lot of glare off the gauge lenses. I took another stab at pics tonight, not as great of quality as I would have liked them to be, but these will have to suffice. I'm pretty happy with how this all came together. It was a lot of work though.
    Cale
  13. #38
    Jan 2003
    lansing, mi
    Quote Originally Posted by 86fiveoh View Post
    The turn signals were easy. I want to say the bulb sockets were for some sort of marker light on a Ford Ranger... I gathered the parts a couple years back at a U-pull yard so I'm a little fuzzy on the details. Same with the seat belt and parking brake indicators. Just cut the plugs off and wire them up to the corresponding wires. An EVTM is a must-have for a job like this. I didn't address the high beam indicator. Other drivers have already let me know the highs are on, haha. I guess the Silverstars are still pretty bright! In all seriousness though, I couldn't come up with a solution to the dilemma that I liked.
    If anyone needs a vehicle speed sensor, I bought one and a pigtail for an sn95 I didn't use because I forgot that bought the VDO vss when I bought all the gauges...
    Cale
  14. #39
    Looks good! Congratulations on getting it all wrapped up!
  15. #40
    Jul 2009
    Telford, Pa
    Looks very good!!
    --Bill
  16. #41
    Looks awesome!
  17. #42
    Very nice Cale!
    Did you tie into the stock wiring for the new gauges and then use new sending units for the oil water and fuel tank?
    Any pics of how you did the wiring?
  18. #43
    Jan 2003
    lansing, mi
    Thanks guys for the nice compliments. Yes I tied into the stock wiring, Mike. If you check out post 30 I wired the gauges to some nice Ford plugs I got from the junkyard. I liked these plugs because they had enough wires to accomodate everything, and they're easy to disconnect and reconnect. I actually had more wires than I had use for and pulled the unused ones out. In the car I cut the factory plugs right out, soldered and heat shrink tubed their companions in place. Oil and water are VDO senders, fuel is the stock sender. The VDO gauge isn't an exact match for the sending unit in the car, so I've been setting the trip odometer and am figuring out when the car needs gas. I thought I had pictures but there aren't any on my memory card unfortunately. The were a few areas of the dash hull behind the cluster I had to clearance for it to fit right- nothing crazy, just time consuming when you try to hack things as little and cleanly as possible.
    Cale
