I have a 4bbl 1985 Mustang GT that is in the shop right now getting some major work done. One job that got completed was to install a new clutch, pressure plate, clutch release bearing, and rear main seal. My 85GT has 1986 headers that were put on by the previous owner, but I was able to locate a correct pair of 85 headers (with the heat risers) and I figured that since the exhaust needed to be removed to do all the clutch work, I may as well have the shop install the correct headers. Anyway, I spoke to the shop today and they said they put the 85 headers on, but they couldn't get the rest of my exhaust to bolt up? They said it was close, but that the 85 headers just wouldn't match up with my Y-pipe.
My question is...did the 85 CFI cars use a different Y-pipe that wouldn't bolt up to the 85 4bbl headers? I thought I had the correct Y-pipe, but if I did the shop should have been able to reconnect my exhaust to the 85 headers. That got me thinking that maybe I have a Y-Pipe for a CFI car and that's why it won't bolt up? I thought I remembered JACook saying that there was a difference in the Y-pipes for CFI cars?
Can anyone help me with this question? Does anyone have pictures of each Y-Pipe so I can see the difference (if there is one)? Why would the 86 headers bolt up, but not the 85? I told the shop to put the 86 headers back on because I can't run open headers, but I really want to run the correct 85 parts (if I can). I just don't understand why these headers wouldn't attach?
Any help and pictures would be greatly appreciated.
