Install weather strip video......http://www.latemodelrestoration.com/...atherstrip-Kit
Scotty
Past Pony's.....
Has anyone installed a head liner on thier convertible? Mine did not come with one as an option originially. Was wondering if it is worth it? I would think it would help quiet the interior down a bit during highway driving and act as an insulator.
I put a headliner in mine. Although it wasn't stock, it makes the interior more cozy and it looks great.
here's pics of mine. its held on the two side rails by Velcro and every time you open and close the convertible you have to re affix the Velcro.
Attachment 85933Attachment 85934Attachment 85935
Ooooooo!
I think I want one of these. I'm pretty sure there's an installation video on the internet somewhere.
Bryan
1983 Mustang GLX Convertible
Headliner does really give the interior a nice clean look. On the to do list after top and seals are replaced later this year.
Sent from Mos Eisley using Tapatalk
--86 GT vert.306,Powerdyne blown 7 psi, E303, ported E7s,MAF conv, BBK shorties n OR H, 3" Mac Pro Dumps, WC T5, 5 lug'd, 17" Bullitts, 3" cowlhood, SN95 Gt front brakes, 4.11s.
--Bill
So I finally got around to replacing my convertible weather stripping yesterday. It took all day because I took my time and I primed and repainted the channels the weather stripping goes in. After hitting with a wire wheel (and ALOT of adhesive remover) to get the old glue out, the metal was exposed. I used a rusty metal primer and satin black paint. Same as my body side trim.
I did not put any 3M weather stripping glue in yet. I wanted to make sure its all seated properly before I make it permanent. The annoying thing is now all the doors and windows don't close right and I will have to pull the panels and adjust them all. I've never done that before. Any suggestions or tutorials that show how?
Here's pics from yesterday. I even replaced the quarter window weather stripping and repainted the rail.
Attachment 85975Attachment 85976Attachment 85977Attachment 85978
Also I had the top down all day yesterday and I had a bitch of a time closing it again. The car sat a whole winter with the top closed and fully stretched. it sits in the sun everyday too so I don't think waiting will make this better. Im gonna visit Auto mat tomorrow and ask them to adjust this. A good convertible top job should enable anyone to close the top without it being a job for 2 strong men. I paid a nice chunk of change for this top and I didn't haggle the price because Auto mat is supposed to be one of the best in the country. I think they have to address this.
Best $25 I ever spent on my vert....shows all the adjustments....................
http://www.latemodelrestoration.com/...Top-Guide-Book
Scotty
Past Pony's.....
fgross2006, I am still waiting for my top to loosen up after 4 years...not a big deal as it comes down to within a couple inches under power and then I can pull down to latch. I also replaced all the weather stripping at that time and had problems with the pillar strip setting right but it eventually did collapse into position and I am happy with it. Additionally, I chose not to glue these two pieces in place and has been all good.
HAD
HAVE
Fgross2006: looks great! Definitely get the convertible top manual listed above from LMR or ebay. It is an excellent resource for our cars and shows all the adjustments. I would have them readjust the top to give you a little more slack if possible. After all winter of being up it should be starting to stretch enough to close it with little effort. They might not be able to if its not a cable adjustment as there really isn't any way to loosen the top material itself once it's installed. That needs to stretch all on its own. One thing that helps is to set it in the sun like you are doing. Also use top conditioner on it to soften it a bit. Just apply it lightly with a sponge dampened with the conditioner. Don't spray it directly on the top. If after the summer it is still too tight, try dampening it with water and let the sun dry it off. The water evaporates off as actually will help it stretch too. If you do that, definitely treat it with conditioner a week before hand to help prevent water spots or fading. Good luck.
--Bill
I played with the front window adjustments for a few hours today. I determined the front pillar post weatherstripping is whats throwing the windows off. To a certain extent the door on the passenger side isnt closing past the top rail weather stripping either. Since the new stripping fits right into place and has no adjustment that I can see, I cant figure out how to correct this condition.
Even putting on new rear quarter weather stripping had an adverse result,
I went to AutoMat today and showed them how tough it is to close the top. he agreed and I have to bring it in on the 24th and leave it for a day to try to adjust it better. He does insist that the hooks should have a spring to tension them. he is gonna look into finding springs.
--Bill
I am going to attempt a top replacement. I will be using the info from this thread for sure. Any opinions on who makes the best replacement top?
85 Vert owner here...my first car bought in 1996
Question: how do you remove all the visible trim at the base of the convertible top? All of my factory Dark Charcoal Gray looks like GM rental car interior gray now. I want to remove all the pieces and repaint them. Do these just snap off and if so is there some methodology to avoid breaking anything? Also, are the side mirrors supposed to be Dark Charcoal as well?
Gripping the wheel his knuckles turn white with desire, the wheels of his mustang exploding on the highway like a slug from a .45 ...True death 400 horsepower maximum performance piercing the night...this is black sunshine
Scotty
Past Pony's.....
I only removed the easy stuff to repaint and left the ones around the bottom on the car when I did mine. If you want to remove them I would recommend getting a trim removal set, I've seen them at Harbor Freight in the auto section. I believe they do clip off and those removal tools make it easier.
Not sure about stock mirror color, both my Pony's I repainted black.
Scotty
Past Pony's.....
The trim around the outer base of the top well area attaches with studs/nuts from the inside...and they can be a real booger to get to. The center piece (adjacent to the trunk lid) is aluminum and purdy solid. However, the adjacent "hockey sticks" are plastic and easy to break and expensive to replace. The quarter window pieces attach the same way. If you are going through this process, I would go ahead and purchase the weather striping as the newer piece is like that later design and allows more room up under the trim pieces for the top boot attachment which in turn creates less chance for scratches. When I did mine back several years ago they did not have available the older quarter window two piece design. I have to cut/modify the later one piece design and it has been fine, no worries.
HAD
HAVE
Scotty
Past Pony's.....
A couple of pages back I noticed a few people discussing top cleaners. I have used bimini top cleaner on my top for quite some time. I am still on my original top.
1985 Mustang GT convertible triple white
Stock survivor
