The later cars - 90-93 - use a completely redesigned top frame. As a result, the top materials are not the same nor the way the top looks. I assume the rear window piece would also be different. I recently retro-fitted a 93 frame to my 86. I don't recall the new canvas top window having the defrost elements. But again, it was a low-end 93 vert so perhaps that item was an option.
--86 GT vert.306,Powerdyne blown 7 psi, E303, ported E7s,MAF conv, BBK shorties n OR H, 3" Mac Pro Dumps, WC T5, 5 lug'd, 17" Bullitts, 3" cowlhood, SN95 Gt front brakes, 4.11s.
--Bill
I ended up going with the following solution mentioned in an earlier post.
"Here is what the CHMSL looks like installed. I took 85stanggt's suggestion and incorporated some strong rare earth magnets into the underside of each end of the light. I ran the wire under the trim at the base of the convertible top and under the hinge cover. The wire is a small gauge so it fits under the trim easily. The light stays firmly in place but I could pull it off and drop it on the trunk in about 10 seconds. It would probably only take about 2-3 minutes to put it back and re-hide the wire. This will come in handy for washing/waxing and for future shows. Overall I'm very pleased with the results and the best part is I have not made any permanent changes. Total cost with the light and materials is ~$75. When you get up close and look from the top you can see about 3mm of wire where it runs from the light to the trim. This is an acceptable trade off for the light being removable."
There is a little hollow (mostly) space on each end of the light housing under the gasket. I cut back a post in that space used as the screw channel and used epoxy to place the magnets. I cut out clearance holes in the gasket to get the magnets as close as possible to the metal body panel. The magnets appear black in the one picture because I am using small black balloons over them for extra insurance that they don't scratch the paint.
So I was trying to find the source of air leaks in my convertible I pulled the top rail off and found the factory insulation petrified and crumbling. I bought some foam at Home depot and stuffed it in under the top rail.
It slowed the leak about 90% but it still leaks because the foam I got is compressible but it lets air pass through.
I will probably have to pull it apart again but im on the right track. What can I put under the top rail that the convertible top weather stripping mushes into?
Heres a pic
Attachment 95719
I answered this question in the other post you started here: http://vb.foureyedpride.com/showthre...40#post1777440
HAD
HAVE
Something like this?
http://solutions.3m.com/wps/portal/3...4872379&rt=rud
Im not visualizing. this is flat tape, that cavity is at least 1 1/2 inch deep. There should be something to fill up that space?
Yes, I had to get mine at a local RV place given the hardware stores don't seem to carry it anymore. The caulk tape is typically 3/4" wide and 1/8" thick, so I just built it up with layers. I would rather utilize the caulk tape than foam given water issues...though my Stang only gets a sponge bath...
HAD
HAVE
Hey guys, recently got an '85 GT vert, and have had the top replaced for $730 (and that was with the guy building me top pads himself), and replaced the suspension with the Eibach Pro Kit. It needs a lot so I'm wondering what to do next. But something I want to look at is my windows. My drivers side window comes out like 1/2" from the top/weatherstripping. I'll post a pic of it ASAP. My passenger side doesn't like to roll up, I have to pull it while I'm rolling it up. Also the inner wipers (not sure what they're called) on the inside of the doors are all cracked and jagged and really look tacky. I don't know if they're available individually or part of the door panels or what.
Thanks guys, this thread is awesome.
Stetsyn Jennings
Hey. Nice vert! Welcome. Read your other posts and am guessing you are using the car as a daily driver and I would recommend tires before anything followed by sub frame connectors-weld in. All foxes can use 'em but verts really need em-tho some here disagree. I would pull front seats and carpet and check for cracks in the floorpan around the seat mounting points. This is good preventative stuff-tho' not glamorous...
Yeah, I am actually getting some sub frame connectors welded on in the next few weeks! It's about to get an engine rebuild courtesy of my uncle (knowing him it's going to come back with more power) so when I get it back that was the first thing I was gonna do, and then go tire shopping so I can get it aligned. I've checked out under the carpet in spots for mold/rust and didn't see any but I was definitely going to replace the carpet in the next couple of months as well, I think the previous owner put in house carpet?!? So, I'm gonna get her together. She's definitely a daily driver for now, until I graduate university. But I want to restore/improve her to the best of my ability.
Time is the biggest factor because I have school throughout the morning and work until midnight m-f. And girlfriend/homework/car/guitar on the weekend haha.
But it'll get there. Thank you!
Stetsyn Jennings
Sweet vert! Love that color!
You might want to look at getting the convertible manual from CJ Pony or LMR. It will show you how to do many things yourself like fixed your window alignment issues. Should be a link on page 1 or 2.
Scotty
Past Pony's.....
I've got a question about a oil leak around the rear end of my 84 vert. I thought it was the pinion seal and replaced it but still leaking. It kinda looks like hydraulic fluid and was wondering if my top has a hydraulic reservoir for the top or are they just electric. And if so ho do I get to it?
The lines get brittle and break. if the fluid is red that is the usual culprit
83 Mustang GLX conv (in sonic blue)4.3/SC -coming soon! "Project Baby"
1988 Lincoln Town Car Limousine, Crafted by American Custom Coach Works- "Project Bertha"
proud member:
10 Hole Mafia
Anti-cowl club
Bent Six Bastards, lol
Scotty
Past Pony's.....
HAD
HAVE
hello! Just a bit of an update, I picked up my replacement top from Fox resto.com (or something like that) it is a KEE top I believe. It included evrtything, glass window, top, pads. For $399.00 on sale. I am going to be attempting this shortly as I get time. At this point a new top would really do the car some justice, it is a '86 GT with the white leather interior and red carpet /dash, White exterior.
Scotty
Past Pony's.....
Hello all...I have an 85 vert that's pretty rough interior and top. I got a hold of a nice top frame off an 83. Will it fit my 85?
Should be as far as I'm aware. I'm definitely no expert though.
Stetsyn Jennings
Scotty
Past Pony's.....
--Bill
