Yeah I would say plastic man. Especially if it won't be in the UV very much.
My zipper has been fine btw for well over a year and I try to put the top down as much as possible.
Thank you all for the input!! I greatly appreciate it very much!! Hoping to maybe buy the new top kit soon. Then maybe get it installed over the summer.
--Bill
Question for the vert guys. I have an 84 LX vert I replaced the top 2 summers ago.
Im sorry that I didn't ask at the time for rear defrost glass be installed at the time. now I'm wondering if I can mod the set up by replacing the rear glass with rear defrost glass and replace the heater HVAC panel with one that has defrost function. Wire it up from rear to dash and tap into a live wire in the dash.
Anyone done something lime this before? I tried searching online and I cant find rear glass defroster ready for any Fox let alone an 84.
I think some of the newer fox verts had rear defrost. Thinking 90 up. Know the tops are different so know you can't just swap the back window into an older top. I remember reading somewhere on one of the sites that someone did swap a newer top and frame onto their older fox Vert and used rear defrost. That's the only one I remember seeing done though.
--Bill
Question for fellow convertible owners.
I had my vert at the interior shop 2 weeks back to adjust my top due to air leaks. I was told theres supposed to be internal springs that keep tension on the J hooks to keep them pointed towards the latch slot. Mine just hang loose.
That's the second time Im being told the J hooks should have spring tension. First was the upholsterer that installed the top 2 summers ago.
I found these replacement springs on LMR
https://lmr.com/item/LRS-8393E3/must...on-spring-8393
has anyone installed these and got the result I'm looking for?
I have seen very similar clips, used retain the stainless trim pieces that surround a front windshield or back glass on older vehicles. They maybe the same ones used to secure a Mustang front and rear glass trim surround....
not sure if they are correct, I have seem some with a clip, that is very similar to a clip, used to retain the stainless trim pieces that surround a front windshield or back glass on older vehicles. They maybe the same clips, used to secure the mustang front and rear glass trim surround....
Scotty
Past Pony's.....
That is the clip I have seen used on many and that I have, and had found an extra one, under the trunk mat, presume to be left over from day or or other. Not sure yet which was correct, this type or the other one, as shown in a prior posting/image or if both were used at some point from 83-93...
I am glad to see that this thread has been a success.
Three years ago when it was started by "magnum 517" there was some concern that it wouldn't get much traffic.
Thanks to all of you who help keep our foxy verts on the road!!!
Ron
Sure looks like one of these clips......?
http://www.cjponyparts.com/window-mo...FQeewAoda1MGBQ
Scotty
Past Pony's.....
The trunk liner was OEM on 85-93 Mustang convertibles. You can find it at a junk yard or occasionally on eBay or Craigslist. You can retrofit it for an 84 vert, as I have, but the back panel won't fit unless you make some modifications. I use only the front and 2 side panels and I also have the trunk mat out of a 92 LX. It makes a big difference.
http://www.ebay.com/itm/1987-1993-Mu...RWcL3Q&vxp=mtr
George Carlin, Rest in peace
Rick
84 GT Convertible
68 Cougar XR7
14 Ford Explorer Limited
I've got 2 sides and a back panel if you are interested.The back panel as I mention would need modifications to fit.
Rick
84 GT Convertible
68 Cougar XR7
I want to add to the topic of repairing convertible latches I had brought up yesterday.
I asked the local interior shop about replacing the springs and he told me, and showed me that my latches are worn badly and have been rigged. Theres a nut and bolt where a drift pin should be on one side. He gave me the url for a supplier he gets from and they have new repro latches for $110 each, compared to LMR charging $134 each. I bet LMR gets from them.
I ordered a new set from this website http://www.hydroe.com/Ford-Mustang-C...ARTS-p-69.html
After I swap them out I will install new springs in the old ones and take them to the local machine shop to see if they can be tightened up with dowel pins or bar stock.
--Bill
Scotty
Past Pony's.....
Not sure why the prior post did not attached, so it makes sense why I added an image...but here is an image of a new clip to secure the trunk covering ...Found this clip down in the trunk quarter panel well.
Check out the previous thread.
http://vb.foureyedpride.com/showthre...e-trunk-panels
Rick
84 GT Convertible
68 Cougar XR7
