Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 376 to 400 of 408
  1. #376
    Yeah I would say plastic man. Especially if it won't be in the UV very much.
  2. #377
    My zipper has been fine btw for well over a year and I try to put the top down as much as possible.
  3. #378
    Jul 2009
    Telford, Pa
    Thank you all for the input!! I greatly appreciate it very much!! Hoping to maybe buy the new top kit soon. Then maybe get it installed over the summer.
    --Bill
  4. #379
    Sep 2014
    Freeport NY
    Question for the vert guys. I have an 84 LX vert I replaced the top 2 summers ago.
    Im sorry that I didn't ask at the time for rear defrost glass be installed at the time. now I'm wondering if I can mod the set up by replacing the rear glass with rear defrost glass and replace the heater HVAC panel with one that has defrost function. Wire it up from rear to dash and tap into a live wire in the dash.
    Anyone done something lime this before? I tried searching online and I cant find rear glass defroster ready for any Fox let alone an 84.
  5. #380
    Sep 2014
    Freeport NY
    EDIT- accidental double post.
  6. #381
    Jul 2009
    Telford, Pa
    I think some of the newer fox verts had rear defrost. Thinking 90 up. Know the tops are different so know you can't just swap the back window into an older top. I remember reading somewhere on one of the sites that someone did swap a newer top and frame onto their older fox Vert and used rear defrost. That's the only one I remember seeing done though.
    --Bill
  7. #382
    Sep 2014
    Freeport NY
    Question for fellow convertible owners.
    I had my vert at the interior shop 2 weeks back to adjust my top due to air leaks. I was told theres supposed to be internal springs that keep tension on the J hooks to keep them pointed towards the latch slot. Mine just hang loose.
    That's the second time Im being told the J hooks should have spring tension. First was the upholsterer that installed the top 2 summers ago.
    I found these replacement springs on LMR
    https://lmr.com/item/LRS-8393E3/must...on-spring-8393
    has anyone installed these and got the result I'm looking for?
  8. #383
    Nov 2010
    Citrus Heights, CA
    This photo of the top latch assembly should help:
    Bryan
    1983 Mustang GLX Convertible
    1984 Mustang Turbo GT Convertible
  9. #384
    I have seen very similar clips, used retain the stainless trim pieces that surround a front windshield or back glass on older vehicles. They maybe the same ones used to secure a Mustang front and rear glass trim surround....
  10. #385
    Quote Originally Posted by awakened View Post
    Help with trunk liner hardware on 1986 GT convertible.
    What type of hardware is used here in the picture to hold the trunk liner on and where can I find it? I called LMR and they said that the eight plastic rivets are the only hardware needed. The rivets are in place but there are two spots just under the weather stripping (one on either side) where some other type of hardware is needed. There is a small raised post that lines up with a hole in the liner.
    not sure if they are correct, I have seem some with a clip, that is very similar to a clip, used to retain the stainless trim pieces that surround a front windshield or back glass on older vehicles. They maybe the same clips, used to secure the mustang front and rear glass trim surround....
  11. #386
    St. Louis, MO.
    I found this shot of a 90 that shows a black clip. My 88 uses a sheet metal screw and a large washer.....LOL
    Scotty
    Past Pony's.....
  12. #387
    Sep 2014
    Freeport NY
    Is that an after market lining? It should fit into an 84 I assume. the size and shape are the same.
    Where did you get that may I ask?
  13. #388
    That is the clip I have seen used on many and that I have, and had found an extra one, under the trunk mat, presume to be left over from day or or other. Not sure yet which was correct, this type or the other one, as shown in a prior posting/image or if both were used at some point from 83-93...
  14. #389
    Dec 2010
    Next to the Chimney
    I am glad to see that this thread has been a success.
    Three years ago when it was started by "magnum 517" there was some concern that it wouldn't get much traffic.
    Thanks to all of you who help keep our foxy verts on the road!!!
    Ron
  15. #390
    St. Louis, MO.
    Sure looks like one of these clips......?
    http://www.cjponyparts.com/window-mo...FQeewAoda1MGBQ
    Scotty
    Past Pony's.....
  16. #391
    Sep 2014
    Freeport NY
    Does anyone know where a trunk liner kit like this can be found?
  17. #392
    Oct 2012
    North Attleboro, Ma
    The trunk liner was OEM on 85-93 Mustang convertibles. You can find it at a junk yard or occasionally on eBay or Craigslist. You can retrofit it for an 84 vert, as I have, but the back panel won't fit unless you make some modifications. I use only the front and 2 side panels and I also have the trunk mat out of a 92 LX. It makes a big difference.
    http://www.ebay.com/itm/1987-1993-Mu...RWcL3Q&vxp=mtr
    George Carlin, Rest in peace
    Rick
    84 GT Convertible
    68 Cougar XR7
    13 Lincoln MKX
  18. #393
    Sep 2014
    Freeport NY
    Quote Originally Posted by smitty54 View Post
    Thanks. There are a few sets on ebay, kinda pricey for crusty look of the used ones but I now have a better ide how to locate a suitable set.
    Then I'll have to find the stock clips that has been the topic this week :-)
  19. #394
    Oct 2012
    North Attleboro, Ma
    I've got 2 sides and a back panel if you are interested.The back panel as I mention would need modifications to fit.
    Rick
    84 GT Convertible
    68 Cougar XR7
    13 Lincoln MKX
  20. #395
    Sep 2014
    Freeport NY
    I want to add to the topic of repairing convertible latches I had brought up yesterday.
    I asked the local interior shop about replacing the springs and he told me, and showed me that my latches are worn badly and have been rigged. Theres a nut and bolt where a drift pin should be on one side. He gave me the url for a supplier he gets from and they have new repro latches for $110 each, compared to LMR charging $134 each. I bet LMR gets from them.
    I ordered a new set from this website http://www.hydroe.com/Ford-Mustang-C...ARTS-p-69.html
    After I swap them out I will install new springs in the old ones and take them to the local machine shop to see if they can be tightened up with dowel pins or bar stock.
  21. #396
    Jul 2009
    Telford, Pa
    Quote Originally Posted by BLK BRD 88 View Post
    Ron
    Yes thank you everyone for keeping this alive. I was hoping that this would be a great source for all myVert brothers and sisters to come for help and info. So far it seems to be working.
    --Bill
  22. #397
    This is gold. Sweet, thanks man!
  23. #398
    St. Louis, MO.
    And thanks for letting me post vert stuff even though mine is an 88...........
    Scotty
    Past Pony's.....
  24. #399
    Not sure why the prior post did not attached, so it makes sense why I added an image...but here is an image of a new clip to secure the trunk covering ...Found this clip down in the trunk quarter panel well.
  25. #400
    Oct 2012
    North Attleboro, Ma
    Check out the previous thread.
    http://vb.foureyedpride.com/showthre...e-trunk-panels
    Rick
    84 GT Convertible
    68 Cougar XR7
    13 Lincoln MKX
