I have way too many projects and time has come to let some go. I have a 1985 Mustang GT that I picked up from the original owner some time ago and it has been sitting in my shop ever since. Medium canyon red metallic, grey interior, manual windows and locks, no cruise, and a solid top car ( no sunroof or t-tops). It has AC and rear defrost. It is pretty much unmolested, which is why I bought it, original except for a SSBC rear disc conversion, an old set of Ford Motorsport lowering springs, GR2 shocks and struts, and subframe connectors. Most of these aftermarket parts have been on the car since it was about new. I have the window sticker, and what appears to be the build sheet and assembly line sheet, and the metal key replacement tags...pretty much if it came with the car new I have it. The interior is in great shape except for a dash cover and a console lid cover. It needs paint and a hood. It has hickory nut damage, no kidding. The rear main seal has started slowly leaking I noticed last time I moved it out of the shop. still has the original clutch and exhaust. Underneath the car is clean and straight. $3000. This would be an excellent candidate for restoration or a good driver. Located in N AL. Text or call 404-213-1994.
