Results 1 to 13 of 13
    FEP Member Tyrel's Avatar
    Nov 2013
    Chilliwack B.C.
    Default question about egr selenoid and tab and tad sensor vacuum lines
    So I want to make sure I have all the vacuum lines right on my car from the above sensors.
    Egr selenoid top vacuum line goes to the egr valve, but where does the bottom one go to? Intake manifold?
    Tab and Tad selenoid I know one or two of them go to the smog pump things but I'm not exactly sure on the routing and dont understand the diagrams. I know they both have two vacuum lines but if someone could provide me with a detailed description of which ones are supply and where the supply comes from and which ones go to the emissions equipment, i would greatly appreciate it. I hate guess work lol.
    And which one is the tab selenoid and which one is the tad selenoid. Better be sure on that one too.
    Anyways, thanks for any and all help.
    FEP Senior Member rob342's Avatar
    Aug 2014
    darien, il
    i'm writing this how i'm writing this, based on your other thread about deleting all this stuff.
    tab/tad can both be disconnected. vacuum lines plugged, electrical connectors off. if you disconnect one, disconnect BOTH. i plugged the vacuum lines right at the solenoids. if you plug them too close to the motor, you will end up blocking vacuum from reaching other things, such as the HVAC controls.
    if you do this, you NEED to block off the 1" line running from the smog pump to the exhaust pipes. if you do not do this and the smog pump pumps air into the exhaust, your o2 sensors will detect the oxygenated air and it can cause your car to detect a false lean condition. this will throw false lean codes, causing the car to run rich(trying to compensate for it thinking it's lean). i just went through this and it was a NIGHTMARE to figure out. in my case it was all caused by a cracked TAD solenoid. since disconnecting them, my car runs great.
    if you disconnect the EGR lines, you need to disconnect the EGR electrical plug as well. if you do not, the car will add timing, see table below.. i only warn you about this because some people leave the egr solenoid plugged in to avoid a the MIL light on the dash. the proper way to do it is to use a resistor in the EGR connector. with the resistor the car will not bump the timing and the light will stay off.
    personally, on my car i chose to remove the smog, but leave the EGR active. it only injects a small amount. it injects up to 11% EGR maximum. it's only active from 900rpm to 2500rpm and only when the motor is at 50% load or less. EGR has no effect on WOT performance, it helps cool the chambers, helps reduce emissions, and helps slightly with fuel economy.
    this is an a9l EGR table(plagiarized from sbftech):
    unless you're upgrading to non-egr heads or a non-egr intake, there is really no reason to remove it unless you want slightly worse economy and more pollution.
    when you remove the TAB/TAD solenoids, leave the wiring intact. the red wires can be used as key on power for your future projects. i have the red wire from my TAD connector wired to the ignition+ wire for my electric fan controllers.
    i just went through all this and i was helped greatly by the experts on sbftech.com if you delete the EGR and need to know which resistor to use in the connector, you can find info like that over there.
    Nov 2013
    Chilliwack B.C.
    I have already taken out the smog pump hoses and plugged the lines to the exhaust and the cylinder heads. Do I absolutely have to unhook the electrical connectors to the tab and tad selenoid? And I plan on keeping the egr. Juat need to figure out where the supply line comes from. Im guessing it comes from under the intake manifold. Please correct me if I'm wrong.
    And the routing of the vacuum lines for the tab and tad sensors. I know there is that one line that splits into two that has the one way check valve in it. What is that for? And where is it supposed to come from and go?
    Aug 2014
    darien, il
    if you unplug the solenoids, the car throws codes that do not effect operation in any way. they will not turn on the check engine light, the codes just tell you those are not present. you should definitely unplug them.
    just an FYI.. if you still have catalytic converters on the car you should remove those too. the smog pump is what prevents them from clogging
    Aug 2014
    darien, il
    the EGR supply comes from the thermactor holes in the exhaust ports. it runs through the heads, through the lower intake, through the upper intake, into the throttle body spacer, through the egr valve, and into the intake plenum.
    *you're thinking too hard. it comes from the little hole in the middle of the 8 intake ports
    i was confusing myself with that too.
    Quote Originally Posted by rob342 View Post
    Umm.... no. EGR comes from the crossover passages in the cylinder heads, if so equipped, whether
    or not those cylinder heads also have thermactor passages. Thermactor and EGR are two completely
    separate systems.
    Cheers,
    Jeff Cook
    Aug 2014
    darien, il
    separate systems.
    yea intake face of the head goes to a small opening in the roof of the third exhaust port from the front when looking at a head with the intakes facing left. sorry i was just trying to answer his question without being overly confusing. next time i'll focus on pleasing experts like you instead.
    Aug 2014
    darien, il
    I just wanted to come back on and apologize. I really like this place and don't want to wear out my welcome. Sorry Jacook. I apologize for my kinda snotty reply. (:
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    Does anyone know which vacuum resistor or restrictor goes on the top vacuum hose coming from the TAD solenoid on my 85 GT 4bbl?
    Quote Originally Posted by Mgino757 View Post
    There shouldn't be one. The line from the top of the TAD solenoids goes through a combination of L, T, and Y
    fittings on it's way to the EGR thermal vacuum switch, but it's otherwise a straight-through deal.
    Apart from the evaporative system, the only other restrictor on the '85 4V HO engine is in the manifold vacuum
    feed to the ignition advance thermal vacuum switch (the one with the electrical connector).
    Cheers,
    Jeff Cook
    Jan 2011
    Virginia Beach, VA
    Mine must have a different configuration. Any idea what color the vacuum resistor would be on the manifold vacuum feed to the PVS for the distributor?
    Mine is green.
    Cheers,
    Jeff Cook
    Jan 2011
    Virginia Beach, VA
    Awesome, thanks!
    Would a red restrictor be a suitable substitute?
