Greetings, all:
My 82 has the 8.8 inch axle on it and the last thing I need to do is replace the rear brake hose. It may have been replaced prior to my purchasing the car, not sure. It looks factory but still needs to go. Would a factory replacement for an 82 car work on this axle? Not sure about spacing between the two axle lines and the end of the hose but it would be great if they would match up. I just need it to work. It appears that the 82 lines were kept when the axle was swapped.
Thanks.
